주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Pentax Super Program Shutter Timing Adjustment
    1. Pentax Super Program Shutter Timing Adjustment, Prepare the shutter: 1 단계, 이미지 2개 중 1개 Pentax Super Program Shutter Timing Adjustment, Prepare the shutter: 1 단계, 이미지 2개 중 2개
      • The shutter should be installed in the camera chassis.
      • Solder jumper wires to the red, brown and white shutter controls signals.
      • Solder a jumper wire to the positive battery terminal.
      • Solder a jumper wire to the ground connection.
      • Install the bottom cover and batteries.
      댓글 쓰기
    2. Pentax Super Program Shutter Timing Adjustment, Prepare the front block: 2 단계, 이미지 3개 중 1개 Pentax Super Program Shutter Timing Adjustment, Prepare the front block: 2 단계, 이미지 3개 중 2개 Pentax Super Program Shutter Timing Adjustment, Prepare the front block: 2 단계, 이미지 3개 중 3개
      • Solder the jumper wires from the shutter control wires.
      • Red wire connection.
      • White wire connection.
      • Brown wire connection.
      • Solder the jumper wire from positive battery.
      • Connect the ground wire to the camera chassis.
      • Connect the shutter release plate to the camera chassis (ground).
      댓글 쓰기
    3. Pentax Super Program Shutter Timing Adjustment, Select the shutter speed: 3 단계, 이미지 2개 중 1개 Pentax Super Program Shutter Timing Adjustment, Select the shutter speed: 3 단계, 이미지 2개 중 2개
      • Turn the mode dial to the 'M' position.
      • Be careful not to let the ball bearing escape when passing through 'Auto' mode (the larger hole).
      • Adjust the shutter speed by grounding the contact posts for the shutter speed selector buttons.
      댓글 쓰기
      • The camera has the necessary electrical connections to operate the shutter, but some of the mechanical actions have to be done manually.
      • Charge the mirror mechanism.
      • Charge the shutter.
      • Press the shutter release.
      • Push the opening curtain latch on the shutter.
      • Push the mirror return latch.
      댓글 쓰기
    4. Pentax Super Program Shutter Timing Adjustment, Adjust curtain travel times: 5 단계, 이미지 1개 중 1개
      • Measure curtain travel times with a shutter tester. If the shutter is far out of spec, it may be necessary to select a slower shutter speed to get a reading.
      • Adjust the lower gear for the opening curtain. Turn clockwise to decrease travel time and counter-clockwise to increase.
      • Adjust the upper gear for the closing curtain.
      • Both curtains should have a travel time of 5.6 ms over 22 mm. Incrementing the gears by one tooth changes the travel time by ~0.05 ms.
      댓글 쓰기
    5. Pentax Super Program Shutter Timing Adjustment, Adjust curtain delay: 6 단계, 이미지 2개 중 1개 Pentax Super Program Shutter Timing Adjustment, Adjust curtain delay: 6 단계, 이미지 2개 중 2개
      • Set the shutter speed to 2000.
      • Adjust the eccentric post until the exposure time measures 0.5 ms.
      • The service manual gives an acceptable range of 0.45 to 0.6 ms for the 1/2000 setting. Other speeds should be accurate at this point.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
1다른 기여자 명과 함께
Sam Gustafson
회원 가입일: 09/01/22
14,444 평판
안내서 78개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 13
지난 30일: 46
전체 시간: 198
