주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Pentax ZX-5n Flash Pivot Replacement
필요한 것
  1. Pentax ZX-5n Flash Pivot Replacement, Remove back cover: 1 단계, 이미지 1개 중 1개
    • Push down on the screw to depress the spring loaded hinge and release the door.
    댓글 쓰기
  2. Pentax ZX-5n Flash Pivot Replacement, Remove bottom cover: 2 단계, 이미지 1개 중 1개
    • Remove six 5.3 mm #00 screws.
    • Remove one 3.4 mm #00 screw.
    • The short screw has a machine thread and screws into the plate underneath. The rest screw into the plastic body.
    댓글 쓰기
  3. Pentax ZX-5n Flash Pivot Replacement, Remove left front cover: 3 단계, 이미지 1개 중 1개
    • Remove three 5.3 mm #00 screws (the bottom-most screw is not always present).
    • Remove one 7.3 mm #00 screw.
    • Remove the remote trigger cover.
    댓글 쓰기
  4. Pentax ZX-5n Flash Pivot Replacement, Remove front cover: 4 단계, 이미지 2개 중 1개 Pentax ZX-5n Flash Pivot Replacement, Remove front cover: 4 단계, 이미지 2개 중 2개
    • Remove two 5.3 mm #00 screw.
    • Gently lift up on the flash housing to help remove the cover if necessary.
    댓글 쓰기
  5. Pentax ZX-5n Flash Pivot Replacement, Remove right front cover: 5 단계, 이미지 1개 중 1개
    • Remove two 3.9 mm #00 screws.
    댓글 쓰기
  6. Pentax ZX-5n Flash Pivot Replacement, Remove eye cup: 6 단계, 이미지 1개 중 1개
    • Slide the eye cup up and off to access the screws underneath.
    댓글 쓰기
  7. Pentax ZX-5n Flash Pivot Replacement, Unscrew top cover: 7 단계, 이미지 3개 중 1개 Pentax ZX-5n Flash Pivot Replacement, Unscrew top cover: 7 단계, 이미지 3개 중 2개 Pentax ZX-5n Flash Pivot Replacement, Unscrew top cover: 7 단계, 이미지 3개 중 3개
    • Remove two 5.3 mm #00 screws by the eyepiece.
    • Remove one 6.8 mm #00 screw in the battery compartment.
    • Remove one 7.0 mm #00 screw near the take up spool.
    댓글 쓰기
  8. Pentax ZX-5n Flash Pivot Replacement, Lift top cover: 8 단계, 이미지 1개 중 1개
    • Lift the cover so it is just free of the body. It is still attached by several wires.
    댓글 쓰기
  9. Pentax ZX-5n Flash Pivot Replacement, Discharge flash capacitors: 9 단계, 이미지 1개 중 1개
    • Use a 1kΩ-10kΩ resistor to discharge the capacitor. Place the resistor between the blue wire, exposed in the previous step, and ground.
    • The flash capacitors store energy at a very high voltage. Failing to discharge the capacitors properly could result in personal injury and/or damage to the camera.
    댓글 쓰기
  10. Pentax ZX-5n Flash Pivot Replacement, Unsolder flash connections: 10 단계, 이미지 1개 중 1개
    • Unsolder one green wire.
    • Unsolder one blue wire.
    • Unsolder one brown wire.
    • Unsolder one black wire.
    댓글 쓰기
  11. Pentax ZX-5n Flash Pivot Replacement, Unsolder remaining connections: 11 단계, 이미지 3개 중 1개 Pentax ZX-5n Flash Pivot Replacement, Unsolder remaining connections: 11 단계, 이미지 3개 중 2개 Pentax ZX-5n Flash Pivot Replacement, Unsolder remaining connections: 11 단계, 이미지 3개 중 3개
    • Pull black wire out from its routed location.
    • Unsolder flex connector
    • Be careful not to overheat the flex circuit. Work in short durations. Allow for cool downs in between if necessary.
    • Some repairs can be performed with the top cover still connected but the flex connection is fragile and easily damaged.
    댓글 쓰기
  12. Pentax ZX-5n Flash Pivot Replacement, Pop up the flash: 12 단계, 이미지 1개 중 1개
    • Push the release button to pop up the flash.
    댓글 쓰기
  13. Pentax ZX-5n Flash Pivot Replacement, Remove flash cover: 13 단계, 이미지 3개 중 1개 Pentax ZX-5n Flash Pivot Replacement, Remove flash cover: 13 단계, 이미지 3개 중 2개 Pentax ZX-5n Flash Pivot Replacement, Remove flash cover: 13 단계, 이미지 3개 중 3개
    • Remove two 2.9mm #000 screws.
    • Remove two 4.4 mm #00 screws.
    • Close the flash and lift off the top cover.
    댓글 쓰기
  14. Pentax ZX-5n Flash Pivot Replacement, Remove flash latch: 14 단계, 이미지 3개 중 1개 Pentax ZX-5n Flash Pivot Replacement, Remove flash latch: 14 단계, 이미지 3개 중 2개 Pentax ZX-5n Flash Pivot Replacement, Remove flash latch: 14 단계, 이미지 3개 중 3개
    • Remove the latch spring.
    • Remove the latch plate. The flash will try to pop up when it is removed.
    댓글 쓰기
  15. Pentax ZX-5n Flash Pivot Replacement, Remove pop up spring: 15 단계, 이미지 1개 중 1개
    • Release the spring arm from the post.
    • Remove the pop up spring.
    댓글 쓰기
  16. Pentax ZX-5n Flash Pivot Replacement, Remove the flash pivot: 16 단계, 이미지 2개 중 1개 Pentax ZX-5n Flash Pivot Replacement, Remove the flash pivot: 16 단계, 이미지 2개 중 2개
    • Remove one 3.3 mm #00 screw.
    • Hold the pivot in place while unscrewing.
    댓글 쓰기
  17. Pentax ZX-5n Flash Pivot Replacement, Install screw: 17 단계, 이미지 1개 중 1개
    • When using the 3D printed part supplied on the device page, install a 4mm #00 screw in the end of the pivot to hold it together.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Sam Gustafson
회원 가입일: 09/01/22
14,384 평판
안내서 78개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 18
지난 30일: 61
전체 시간: 1,221
