주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Philips DC320 37 Connector Replacement
필요한 것
    1. Philips DC320 37 Connector Replacement, Docking entertainment system: 1 단계, 이미지 1개 중 1개
      • Pry off the four white feet with the pointed end of the spudger
      댓글 쓰기
    2. Philips DC320 37 Connector Replacement: 2 단계, 이미지 1개 중 1개
      • Gently unscrew the four 15.5 mm Phillips #2 screws that hold the bottom panel to the dock.
      댓글 쓰기
    3. Philips DC320 37 Connector Replacement: 3 단계, 이미지 1개 중 1개
      • Use the flat end of the spudger to pry the lid off from the two connectors holding it to the body of the dock.
      • The connectors on the panel are fragile and may break.
      댓글 쓰기
    4. Philips DC320 37 Connector Replacement: 4 단계, 이미지 3개 중 1개 Philips DC320 37 Connector Replacement: 4 단계, 이미지 3개 중 2개 Philips DC320 37 Connector Replacement: 4 단계, 이미지 3개 중 3개
      • Carefully pull up and out the four electrical connectors and two ribbon connectors that connect the bottom panel to the dock.
      • Electrical Connectors
      • Ribbon Connectors
      • The cables do not have a lot of slack in them. Be careful not to break the connectors.
      • One wire is soldered onto the bottom panel. Be careful not to break this bond.
      댓글 쓰기
    1. Philips DC320 37 Connector Replacement, Connector: 5 단계, 이미지 1개 중 1개
      • Pull the copper plate out of the way of the two Phillips #00 screws in the middle of the connector.
      댓글 쓰기
    2. Philips DC320 37 Connector Replacement: 6 단계, 이미지 1개 중 1개
      • Unscrew the two 7 mm Phillips #00 screws holding the connector together.
      • Unscrew the four 5 mm Phillips #00 screws holding the connector to the dock
      댓글 쓰기
    3. Philips DC320 37 Connector Replacement: 7 단계, 이미지 3개 중 1개 Philips DC320 37 Connector Replacement: 7 단계, 이미지 3개 중 2개 Philips DC320 37 Connector Replacement: 7 단계, 이미지 3개 중 3개
      • Turn the dock so that you are looking at the front of the dock.
      • Pull out the black U-shaped piece.
      • Pull out the iPhone/iPod support cradle.
      • Pull out the two springs.
      댓글 쓰기
    4. Philips DC320 37 Connector Replacement: 8 단계, 이미지 1개 중 1개
      • Turn the dock so that you are looking at the bottom of the dock.
      • Pop out the black connector frame and attached circuit board from the body of the dock.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
5다른 기여자 명과 함께
Greg Lane
회원 가입일: 04/16/13
39 평판
안내서 4개를 작성함
Cal Poly, Team 3-48, Amido Spring 2013 Cal Poly, Team 3-48, Amido Spring 2013 회원
CPSU-AMIDO-S13S3G48
4 회원들
안내서 54개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 10
지난 30일: 40
전체 시간: 1,557
