주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Philips DC320 37 LCD Screen Replacement
필요한 것
  1. Philips DC320 37 LCD Screen Replacement, Docking entertainment system: 1 단계, 이미지 1개 중 1개
    • Pry off the four white feet with the pointed end of the spudger
    댓글 쓰기
  2. Philips DC320 37 LCD Screen Replacement: 2 단계, 이미지 1개 중 1개
    • Gently unscrew the four 15.5 mm Phillips #2 screws that hold the bottom panel to the dock.
    댓글 쓰기
  3. Philips DC320 37 LCD Screen Replacement: 3 단계, 이미지 1개 중 1개
    • Use the flat end of the spudger to pry the lid off from the two connectors holding it to the body of the dock.
    • The connectors on the panel are fragile and may break.
    댓글 쓰기
  4. Philips DC320 37 LCD Screen Replacement: 4 단계, 이미지 3개 중 1개 Philips DC320 37 LCD Screen Replacement: 4 단계, 이미지 3개 중 2개 Philips DC320 37 LCD Screen Replacement: 4 단계, 이미지 3개 중 3개
    • Carefully pull up and out the four electrical connectors and two ribbon connectors that connect the bottom panel to the dock.
    • Electrical Connectors
    • Ribbon Connectors
    • The cables do not have a lot of slack in them. Be careful not to break the connectors.
    • One wire is soldered onto the bottom panel. Be careful not to break this bond.
    댓글 쓰기
  5. Philips DC320 37 LCD Screen Replacement, Speaker: 5 단계, 이미지 1개 중 1개
    • Unscrew the two 6 mm Phillips #00 screws attaching the back panel to device.
    댓글 쓰기
  6. Philips DC320 37 LCD Screen Replacement: 6 단계, 이미지 3개 중 1개 Philips DC320 37 LCD Screen Replacement: 6 단계, 이미지 3개 중 2개 Philips DC320 37 LCD Screen Replacement: 6 단계, 이미지 3개 중 3개
    • Slide the back panel towards top of the device and lift away from the device to detach back panel.
    댓글 쓰기
  7. Philips DC320 37 LCD Screen Replacement: 7 단계, 이미지 1개 중 1개
    • Unscrew the four 16 mm Phillips #2 screws attaching the speaker unit to device.
    댓글 쓰기
  8. Philips DC320 37 LCD Screen Replacement: 8 단계, 이미지 2개 중 1개 Philips DC320 37 LCD Screen Replacement: 8 단계, 이미지 2개 중 2개
    • Slide the speaker towards the bottom of the device to remove.
    댓글 쓰기
  9. Philips DC320 37 LCD Screen Replacement, LCD Screen: 9 단계, 이미지 3개 중 1개 Philips DC320 37 LCD Screen Replacement, LCD Screen: 9 단계, 이미지 3개 중 2개 Philips DC320 37 LCD Screen Replacement, LCD Screen: 9 단계, 이미지 3개 중 3개
    • Unscrew the seven 6 mm Phillips #00 screws holding the grey side piece to the black front panel.
    • Five of the Phillips #00 screws are on the LCD board. The other two are on the dock's bottom circuit board.
    • Unscrew the two 8 mm Phillips #1 screws that go through the grey piece and the LCD motherboard.
    댓글 쓰기
  10. Philips DC320 37 LCD Screen Replacement: 10 단계, 이미지 1개 중 1개
    • Remove the ribbon cable from the ZIF connector by pulling out the two black tabs with the pointed end of the spudger then pulling the cable straight out of the connector.
    댓글 쓰기
  11. Philips DC320 37 LCD Screen Replacement: 11 단계, 이미지 2개 중 1개 Philips DC320 37 LCD Screen Replacement: 11 단계, 이미지 2개 중 2개
    • Remove the grey side piece from the black front panel by pulling it straight up. It should easily slide off.
    댓글 쓰기
  12. Philips DC320 37 LCD Screen Replacement: 12 단계, 이미지 2개 중 1개 Philips DC320 37 LCD Screen Replacement: 12 단계, 이미지 2개 중 2개
    • Unscrew the six 8 mm Phillips #1 screws holding the LCD screen to the black front panel.
    • Unscrew the two 6 mm Phillips #00 screws from the top of the panel holding the the LCD screen to the front panel.
    • Pull the LCD and circuit board off of the front panel.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
5다른 기여자 명과 함께
Greg Lane
회원 가입일: 04/16/13
39 평판
안내서 4개를 작성함
Cal Poly, Team 3-48, Amido Spring 2013 Cal Poly, Team 3-48, Amido Spring 2013 회원
CPSU-AMIDO-S13S3G48
4 회원들
안내서 13개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 26
전체 시간: 1,804
