주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Philips DVP642 Disc Tray Replacement
필요한 것
    1. Philips DVP642 Disc Tray Replacement, Top Panel: 1 단계, 이미지 2개 중 1개 Philips DVP642 Disc Tray Replacement, Top Panel: 1 단계, 이미지 2개 중 2개
      • Remove four 7.5 mm Phillips screws on the both sides (2 on each side).
      • Remove five 7.5 mm Phillips screws on the back of the player.
      댓글 쓰기
    2. Philips DVP642 Disc Tray Replacement: 2 단계, 이미지 2개 중 1개 Philips DVP642 Disc Tray Replacement: 2 단계, 이미지 2개 중 2개
      • Lift the top panel from the back and remove. It should come off without being forced. There is a lip near the front so you many need to slide the top panel back slightly to remove it.
      댓글 쓰기
    1. Philips DVP642 Disc Tray Replacement, Disc Tray: 3 단계, 이미지 2개 중 1개 Philips DVP642 Disc Tray Replacement, Disc Tray: 3 단계, 이미지 2개 중 2개
      • Remove two 7.5 mm screws, one on each side of the player.
      • Remove three 7.5mm screws from the bottom of the player.
      • Note that the three screws from the bottom are slightly different screws.
      댓글 쓰기
    2. Philips DVP642 Disc Tray Replacement: 4 단계, 이미지 1개 중 1개
      • Detach all the ribbon wires (4) attached to the motherboard
      댓글 쓰기
    3. Philips DVP642 Disc Tray Replacement: 5 단계, 이미지 3개 중 1개 Philips DVP642 Disc Tray Replacement: 5 단계, 이미지 3개 중 2개 Philips DVP642 Disc Tray Replacement: 5 단계, 이미지 3개 중 3개
      • The first 3 ribbon wires can be removed by grasping near the head and gently pulling up.
      • Locate the skinny fourth ribbon wire near the top right of the motherboard.
      • Remove the fourth ribbon wire by grasping both sides of the black clip and pulling up. When reinserting, pull the black clip up, insert the ribbon ribbon, and push the black clip back down.
      • Be firm, but gentle when pulling to avoid pulling the wires off the head.
      댓글 쓰기
    4. Philips DVP642 Disc Tray Replacement: 6 단계, 이미지 1개 중 1개
      • Now remove the remaining three 7.5 mm Phillips screws that hold the disc tray to the body.
      • Remove the 12 mm Phillips screw that secures the tray to the upright metal frame.
      • Remove the two 7.5 mm Phillips screws that attach the disc tray to the motherboard and front panel.
      댓글 쓰기
    5. Philips DVP642 Disc Tray Replacement: 7 단계, 이미지 1개 중 1개
      • Gently pull forward and upward to free disc tray.
      댓글 쓰기
    6. Philips DVP642 Disc Tray Replacement: 8 단계, 이미지 1개 중 1개
      • Tilt the tray sideways and then pull back gently to separate the tray from the front panel.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 6명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Toby Goldsteinholm
회원 가입일: 10/09/11
372 평판
안내서 2개를 작성함
Cal Poly, Team 21-20, Maness Fall 2011 Cal Poly, Team 21-20, Maness Fall 2011 회원
CPSU-MANESS-F11S21G20
4 회원들
안내서 24개를 작성함
3가이드 댓글
If you work at it, inserting a small screwdriver at appropriate places, you can get the drawer front off (do this with drawer open). This is easier than removing the front panel from the player.
Steve Emerson - 답글 공유
I failed huhuhu
Hello kitty - 답글 공유
not useful without source for parts. i believe the dvd drive is a sony oem.
mapatouli - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 14
지난 30일: 62
전체 시간: 10,161
