주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Philips DVP642 Power Supply Replacement
필요한 것
    1. Philips DVP642 Power Supply Replacement, Top Panel: 1 단계, 이미지 2개 중 1개 Philips DVP642 Power Supply Replacement, Top Panel: 1 단계, 이미지 2개 중 2개
      • Remove four 7.5 mm Phillips screws on the both sides (2 on each side).
      • Remove five 7.5 mm Phillips screws on the back of the player.
      댓글 쓰기
    2. Philips DVP642 Power Supply Replacement: 2 단계, 이미지 2개 중 1개 Philips DVP642 Power Supply Replacement: 2 단계, 이미지 2개 중 2개
      • Lift the top panel from the back and remove. It should come off without being forced. There is a lip near the front so you many need to slide the top panel back slightly to remove it.
      댓글 쓰기
    1. Philips DVP642 Power Supply Replacement, Power Supply: 3 단계, 이미지 2개 중 1개 Philips DVP642 Power Supply Replacement, Power Supply: 3 단계, 이미지 2개 중 2개
      • Slide the power cord out from the case.
      • Be sure not to lose the rubber clip that is wrapped around the cord.
      댓글 쓰기
    2. Philips DVP642 Power Supply Replacement: 4 단계, 이미지 1개 중 1개
      • Remove the ribbon attached to the power supply by pushing the latch and gently pulling up.
      댓글 쓰기
    3. Philips DVP642 Power Supply Replacement: 5 단계, 이미지 2개 중 1개 Philips DVP642 Power Supply Replacement: 5 단계, 이미지 2개 중 2개
      • Now remove this ribbon wire by grasping the white head firmly and pulling up gently.
      댓글 쓰기
    4. Philips DVP642 Power Supply Replacement: 6 단계, 이미지 2개 중 1개 Philips DVP642 Power Supply Replacement: 6 단계, 이미지 2개 중 2개
      • Remove these two 7.5m Phillips screws and the matching set at the other end of the supply.
      • Now remove the ribbon that attaches the power supply to the motherboard by grasping the white head and gently pulling up.
      댓글 쓰기
    5. Philips DVP642 Power Supply Replacement: 7 단계, 이미지 3개 중 1개 Philips DVP642 Power Supply Replacement: 7 단계, 이미지 3개 중 2개 Philips DVP642 Power Supply Replacement: 7 단계, 이미지 3개 중 3개
      • Remove the last screw.
      • Pinch this plastic prong and slide the power supply up and over it. The power supply should lift free.
      댓글 쓰기
    6. Philips DVP642 Power Supply Replacement: 8 단계, 이미지 2개 중 1개 Philips DVP642 Power Supply Replacement: 8 단계, 이미지 2개 중 2개
      • Your power supply is now free!
      • If the fuse circled here is blown (the small wire in the glass tube is missing or broken), remove it by pinching it tightly and pulling it straight out.
      • You can find a new fuse here.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 7명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Toby Goldsteinholm
회원 가입일: 10/09/11
372 평판
안내서 2개를 작성함
Cal Poly, Team 21-20, Maness Fall 2011 Cal Poly, Team 21-20, Maness Fall 2011 회원
CPSU-MANESS-F11S21G20
4 회원들
안내서 24개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 18
지난 30일: 64
전체 시간: 14,471
