주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Philips PD9000 37 Battery Replacement
필요한 것
  1. Philips PD9000 37 Battery Replacement, White Outer Housing: 1 단계, 이미지 3개 중 1개 Philips PD9000 37 Battery Replacement, White Outer Housing: 1 단계, 이미지 3개 중 2개 Philips PD9000 37 Battery Replacement, White Outer Housing: 1 단계, 이미지 3개 중 3개
    • Lay the player flat so the bottom outside is showing. Using the Phillips #0 screwdriver, unscrew all the housing screws on the bottom of the player.
    • Have the player sitting upright, remove the rubber stoppers in order to get to the screw. Unscrew the inside screws by the screen using the Philips #0 screwdriver.
    • Remove the rubber stoppers for the bottom two screws as well. Unscrew the middle two screws.
    댓글 쓰기
  2. Philips PD9000 37 Battery Replacement: 2 단계, 이미지 2개 중 1개 Philips PD9000 37 Battery Replacement: 2 단계, 이미지 2개 중 2개
    • Open the disc flap and remove the screws inside with the Phillips #0 screwdriver. There will be three screws.
    댓글 쓰기
  3. Philips PD9000 37 Battery Replacement: 3 단계, 이미지 3개 중 1개 Philips PD9000 37 Battery Replacement: 3 단계, 이미지 3개 중 2개 Philips PD9000 37 Battery Replacement: 3 단계, 이미지 3개 중 3개
    • Start removing the inside black face plate of the player by using a prying method between the white outer housing and the black face plate with a metal spudger.
    • Pull the black face plate off once you have pried it from the white housing. The bottom inside layer should pop off.
    • Using the same prying method with the metal spudger, start prying off the screens white outer housing.
    댓글 쓰기
  4. Philips PD9000 37 Battery Replacement: 4 단계, 이미지 3개 중 1개 Philips PD9000 37 Battery Replacement: 4 단계, 이미지 3개 중 2개 Philips PD9000 37 Battery Replacement: 4 단계, 이미지 3개 중 3개
    • The light panel on the front can just pop right off.
    • To remove the metal bar against the battery, unscrew the screws with the phillips #0 screwdriver.
    • After unscrewing you can just lift the metal bar off.
    댓글 쓰기
  5. Philips PD9000 37 Battery Replacement, Battery: 5 단계, 이미지 2개 중 1개 Philips PD9000 37 Battery Replacement, Battery: 5 단계, 이미지 2개 중 2개
    • Take the metal rounded rectangle spudger and place under battery edge.
    • Avoid breaking plastic cover.
    • press down hard on held end of spudger, you will hear the battery un-stick.
    댓글 쓰기
  6. Philips PD9000 37 Battery Replacement: 6 단계, 이미지 2개 중 1개 Philips PD9000 37 Battery Replacement: 6 단계, 이미지 2개 중 2개
    • Use a soldering iron to melt the metal connecting the battery wires to the mother board.
    • Quickly remove each wire after melting the metal
    • Soldering iron is HOT and will burn you.
    • Wires will get HOT and may burn you.
    댓글 쓰기
  7. Philips PD9000 37 Battery Replacement: 7 단계, 이미지 1개 중 1개
    • Properly dispose of battery as soon as possible
    • If battery is not disposed of, it may bloat and explode
    • If battery leaks, dispose of right away and wash hands.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 5명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Kendal Cler
회원 가입일: 09/28/15
969 평판
안내서 6개를 작성함
3가이드 댓글
Where can this battery be bought? After a year using, playing time is down to 3 hours
L.Johnson - 답글 공유
Yeah. Where can I get the battery?
Bryan Allen - 답글 공유
This tutorial is completely worthless if one doesn't have a battery to replace the one removed. Now two people have asked where to get a replacement yet you have not responded. Undoubtedly countless others have come by looking for a suitable replacement and saw that there was no response and no solution. Congratulations on helping no one. It would seem you're nothing more than a blowhard, a big show off, “Oh look at me I am fixing my bad battery. Aren't you impressed?” I'm not.
kurt - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 10
지난 30일: 61
전체 시간: 8,570
