주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Philips PD9000 37 Disk Drive Replacement
필요한 것
  1. Philips PD9000 37 Disk Drive Replacement, White Outer Housing: 1 단계, 이미지 3개 중 1개 Philips PD9000 37 Disk Drive Replacement, White Outer Housing: 1 단계, 이미지 3개 중 2개 Philips PD9000 37 Disk Drive Replacement, White Outer Housing: 1 단계, 이미지 3개 중 3개
    • Lay the player flat so the bottom outside is showing. Using the Phillips #0 screwdriver, unscrew all the housing screws on the bottom of the player.
    • Have the player sitting upright, remove the rubber stoppers in order to get to the screw. Unscrew the inside screws by the screen using the Philips #0 screwdriver.
    • Remove the rubber stoppers for the bottom two screws as well. Unscrew the middle two screws.
    댓글 쓰기
  2. Philips PD9000 37 Disk Drive Replacement: 2 단계, 이미지 2개 중 1개 Philips PD9000 37 Disk Drive Replacement: 2 단계, 이미지 2개 중 2개
    • Open the disc flap and remove the screws inside with the Phillips #0 screwdriver. There will be three screws.
    댓글 쓰기
  3. Philips PD9000 37 Disk Drive Replacement: 3 단계, 이미지 3개 중 1개 Philips PD9000 37 Disk Drive Replacement: 3 단계, 이미지 3개 중 2개 Philips PD9000 37 Disk Drive Replacement: 3 단계, 이미지 3개 중 3개
    • Start removing the inside black face plate of the player by using a prying method between the white outer housing and the black face plate with a metal spudger.
    • Pull the black face plate off once you have pried it from the white housing. The bottom inside layer should pop off.
    • Using the same prying method with the metal spudger, start prying off the screens white outer housing.
    댓글 쓰기
  4. Philips PD9000 37 Disk Drive Replacement: 4 단계, 이미지 3개 중 1개 Philips PD9000 37 Disk Drive Replacement: 4 단계, 이미지 3개 중 2개 Philips PD9000 37 Disk Drive Replacement: 4 단계, 이미지 3개 중 3개
    • The light panel on the front can just pop right off.
    • To remove the metal bar against the battery, unscrew the screws with the phillips #0 screwdriver.
    • After unscrewing you can just lift the metal bar off.
    댓글 쓰기
  5. Philips PD9000 37 Disk Drive Replacement, Disk Drive: 5 단계, 이미지 2개 중 1개 Philips PD9000 37 Disk Drive Replacement, Disk Drive: 5 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Using the Tweezers from the iFixit repair tools, pull the two white plastic connectors that connect the disk drive to the motherboard off detaching the disk drive from the motherboard.
    댓글 쓰기
  6. Philips PD9000 37 Disk Drive Replacement: 6 단계, 이미지 1개 중 1개
    • Grab the sides of the disk drive and gently pull straight up to detach the disk drive.
    • The white ribbon is not connected to the actual drive, so it can be ignored.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Julia Sheremet
회원 가입일: 09/28/15
303 평판
안내서 2개를 작성함
1가이드 댓글
Hi! Where I can buy the Philips PD9000 37 Disk Drive Replacement because I can´t find it... Thanks
Eduardo - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 19
지난 30일: 59
전체 시간: 4,545
