주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Philips SBA1060 Capacitor Replacement
필요한 것
    1. Philips SBA1060 Capacitor Replacement, Battery Casing: 1 단계, 이미지 1개 중 1개
      • Remove the back cover by sliding it off.
      • Remove the 3 AAA batteries.
      댓글 쓰기
    2. Philips SBA1060 Capacitor Replacement: 2 단계, 이미지 3개 중 1개 Philips SBA1060 Capacitor Replacement: 2 단계, 이미지 3개 중 2개 Philips SBA1060 Capacitor Replacement: 2 단계, 이미지 3개 중 3개
      • Unscrew the nine exterior screws on the back panel using a PH0-size Philips-head screwdriver.
      • A larger screwdriver head and more force may be required for damaged screws.
      • Remove the triangular end piece by pulling it straight off.
      댓글 쓰기
    3. Philips SBA1060 Capacitor Replacement: 3 단계, 이미지 2개 중 1개 Philips SBA1060 Capacitor Replacement: 3 단계, 이미지 2개 중 2개
      • Remove the colored grill by sliding it off in the direction of the removed end piece.
      • Pry off the back battery panel with the plastic opening tool.
      • Be careful to avoid tearing any wires.
      댓글 쓰기
    1. Philips SBA1060 Capacitor Replacement, Capacitor: 4 단계, 이미지 1개 중 1개
      • Remove the two screws on opposite ends of the circuit board with the PH0 size philips head screw driver.
      • Slowly pull the circuit board out of the device
      • NOTE: Be careful not to damage any of the wires protruding from the back of the circuit board.
      댓글 쓰기
    2. Philips SBA1060 Capacitor Replacement: 5 단계, 이미지 2개 중 1개 Philips SBA1060 Capacitor Replacement: 5 단계, 이미지 2개 중 2개
      • Flip the device and remove the battery plug from the circuit board by pulling out the plugs to fully remove back panel.
      • Remove the speaker plugs from the circuit board by pulling out the plugs. They are located on opposite sides of the circuit board.
      • NOTE: When reassembling, note that the speaker with the red wire goes to the red plug, and the speaker with the white wire goes to the adjacent white plug.
      • Remove the light plug from the circuit board.
      • NOTE: This plug is twice as wide as the speaker and battery plugs.
      댓글 쓰기
    3. Philips SBA1060 Capacitor Replacement: 6 단계, 이미지 2개 중 1개 Philips SBA1060 Capacitor Replacement: 6 단계, 이미지 2개 중 2개
      • Locate the capacitor and carefully slide it out of the circuit board.
      • NOTE: The capacitor will be a cylindrical object protruding vertically near the center of the circuit board.
      • Slide the prongs of the replacement capacitor into the two holes of the circuit board where the original capacitor was removed from.
      • Reassemble the speaker.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
5다른 기여자 명과 함께
April Driscoll
회원 가입일: 10/21/13
321 평판
안내서 3개를 작성함
Clemson, Team 14-4, Benson Fall 2013 Clemson, Team 14-4, Benson Fall 2013 회원
CLEM-BENSON-F13S14G4
3 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 25
전체 시간: 1,062
