주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
PlayStation 4 Slim Optical Disc Drive Replacement
필요한 것
  1. PlayStation 4 Slim Optical Disc Drive Replacement, Bottom Cover: 1 단계, 이미지 3개 중 1개 PlayStation 4 Slim Optical Disc Drive Replacement, Bottom Cover: 1 단계, 이미지 3개 중 2개 PlayStation 4 Slim Optical Disc Drive Replacement, Bottom Cover: 1 단계, 이미지 3개 중 3개
    • Locate the plastic warranty sticker next to the three ports on the side of the console.
    • Remove the warranty sticker by peeling it off with any kind of spudger.
    • Removing the warranty sticker will NOT cause your warranty to be null and void.
    댓글 쓰기
  2. PlayStation 4 Slim Optical Disc Drive Replacement: 2 단계, 이미지 2개 중 1개 PlayStation 4 Slim Optical Disc Drive Replacement: 2 단계, 이미지 2개 중 2개
    • Unscrew and remove the now exposed 5.0mm screw using a TR8 security Torx screwdriver with a counter-clockwise motion.
    댓글 쓰기
  3. PlayStation 4 Slim Optical Disc Drive Replacement: 3 단계, 이미지 3개 중 1개 PlayStation 4 Slim Optical Disc Drive Replacement: 3 단계, 이미지 3개 중 2개 PlayStation 4 Slim Optical Disc Drive Replacement: 3 단계, 이미지 3개 중 3개
    • Place the Playstation 4 Slim upside down with the side of the screw you just removed facing you.
    • Pry up on the two corners that are facing you with your fingers.
    • This may take a bit of force to open up and you will hear a fairly loud click when the bottom cover detaches.
    • Remove the bottom cover by sliding it towards the back corners and lifting up.
    댓글 쓰기
  4. PlayStation 4 Slim Optical Disc Drive Replacement, Power Supply: 4 단계, 이미지 3개 중 1개 PlayStation 4 Slim Optical Disc Drive Replacement, Power Supply: 4 단계, 이미지 3개 중 2개 PlayStation 4 Slim Optical Disc Drive Replacement, Power Supply: 4 단계, 이미지 3개 중 3개
    • Place the Playstation 4 Slim right side up, with the PS logo on top and the side with the words "SONY" and "PS4" facing you.
    • This may take a bit of force to open and you will hear a fairly loud click when the top cover detaches.
    • Remove the top cover by sliding it towards the back corners and lifting up.
    댓글 쓰기
  5. PlayStation 4 Slim Optical Disc Drive Replacement: 5 단계, 이미지 3개 중 1개 PlayStation 4 Slim Optical Disc Drive Replacement: 5 단계, 이미지 3개 중 2개 PlayStation 4 Slim Optical Disc Drive Replacement: 5 단계, 이미지 3개 중 3개
    • Unscrew and remove the two screws (left one 31.0mm and right one 24.0mm) using a T8 screwdriver with a counter-clockwise motion.
    • Unscrew and remove the 3.0mm screw using a Phillips #1 screwdriver with a counter-clockwise motion.
    댓글 쓰기
  6. PlayStation 4 Slim Optical Disc Drive Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the four 16mm Philips screws holding the power supply in place.
    댓글 쓰기
  7. PlayStation 4 Slim Optical Disc Drive Replacement: 7 단계, 이미지 2개 중 1개 PlayStation 4 Slim Optical Disc Drive Replacement: 7 단계, 이미지 2개 중 2개
    • Remove the metal sheet from the top of the power supply by grabbing and lifting up with your hands.
    댓글 쓰기
  8. PlayStation 4 Slim Optical Disc Drive Replacement: 8 단계, 이미지 2개 중 1개 PlayStation 4 Slim Optical Disc Drive Replacement: 8 단계, 이미지 2개 중 2개
    • Remove the antenna from the top of the power supply by guiding the wire with your fingers through the groves underneath the metal panel.
    댓글 쓰기
  9. PlayStation 4 Slim Optical Disc Drive Replacement: 9 단계, 이미지 2개 중 1개 PlayStation 4 Slim Optical Disc Drive Replacement: 9 단계, 이미지 2개 중 2개
    • Flip the Playstation 4 Slim onto its back.
    • Unscrew and remove the 4.0mm screw using a Phillips #1 screwdriver with a counter-clockwise motion. This screw holds the power supply in place
    댓글 쓰기
  10. PlayStation 4 Slim Optical Disc Drive Replacement: 10 단계, 이미지 3개 중 1개 PlayStation 4 Slim Optical Disc Drive Replacement: 10 단계, 이미지 3개 중 2개 PlayStation 4 Slim Optical Disc Drive Replacement: 10 단계, 이미지 3개 중 3개
    • Use a plastic opening tool to make space between the power supply and console by wedging and wiggling it in-between the two.
    • Lift the power supply up and onto its back on the metal sheet using your hands.
    댓글 쓰기
  11. PlayStation 4 Slim Optical Disc Drive Replacement: 11 단계, 이미지 3개 중 1개 PlayStation 4 Slim Optical Disc Drive Replacement: 11 단계, 이미지 3개 중 2개 PlayStation 4 Slim Optical Disc Drive Replacement: 11 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Disconnect the wire connection from the power supply by firmly gripping it with your fingers or tweezers and pulling out.
    • Remove the power supply completely by grabbing and lifting up with your hands.
    댓글 쓰기
  12. PlayStation 4 Slim Optical Disc Drive Replacement, Optical Disc Drive: 12 단계, 이미지 2개 중 1개 PlayStation 4 Slim Optical Disc Drive Replacement, Optical Disc Drive: 12 단계, 이미지 2개 중 2개
    • Unscrew and remove the 31.0mm screw using a T8 screwdriver with a counter-clockwise motion.
    • Unscrew and remove the 10x 5.0mm screws using a Phillips #1 screwdriver with a counter-clockwise motion.
    댓글 쓰기
    • If there are black plastic rivets in place of some screws, pull them out using pliers. They aren't necessary.
    댓글 쓰기
  13. PlayStation 4 Slim Optical Disc Drive Replacement: 14 단계, 이미지 2개 중 1개 PlayStation 4 Slim Optical Disc Drive Replacement: 14 단계, 이미지 2개 중 2개
    • Remove the metal plate by grabbing the edges and lifting up with your hands.
    댓글 쓰기
  14. PlayStation 4 Slim Optical Disc Drive Replacement: 15 단계, 이미지 2개 중 1개 PlayStation 4 Slim Optical Disc Drive Replacement: 15 단계, 이미지 2개 중 2개
    • Unscrew and remove the two 3.0mm screws using a PH000 screwdriver with a counter-clockwise motion.
    댓글 쓰기
  15. PlayStation 4 Slim Optical Disc Drive Replacement: 16 단계, 이미지 2개 중 1개 PlayStation 4 Slim Optical Disc Drive Replacement: 16 단계, 이미지 2개 중 2개
    • Remove the disk drive out by pinching on either side of the two black plastic "claws" and lifting up with your hand.
    • TIP: Before lifting the mechanism, note the white plastic rocker arm engaged with the center wheel. The underside of that rocker arm has a pin near the edge that engages with a slider mechanism underneath. When reassembling, you need to line this pin up again the same way.
    댓글 쓰기
결론
If you need to go deeper to fix your drive, see the comment section for suggestions.
취소: 해당 안내서를 완성하지 않았습니다.
다른 121명이 해당 안내서를 완성하였습니다.
작성자
10다른 기여자 명과 함께
Hernan Rodriguez
회원 가입일: 01/24/18
4,910 평판
안내서 3개를 작성함
27가이드 댓글
incomplete guide, what replacement? the last step is taking the cover off but what about the disk drive?
Yegor Ilchuk - 답글 공유
its easy you need to take off the bottom cover and the black thingy
Albert Einstein - 답글 공유
Yeah, where's the ending to this?
Ben Baptist - 답글 공유
To remove the complete drive you have to remove the motherboard. with the motherboard removed some of the above steps may not be necessary.
This guide is useful if you just need to remove disc or clean laser.
Freddie Parsons - 답글 공유
when replacing do you have to swap a board like the PS4’s of the past?
Frank Ferrante - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 79
지난 7일: 508
지난 30일: 2,362
전체 시간: 233,111
