주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
PlayStation Move Battery Replacement
필요한 것
  1. PlayStation Move  Battery Replacement, Battery: 1 단계, 이미지 3개 중 1개 PlayStation Move  Battery Replacement, Battery: 1 단계, 이미지 3개 중 2개 PlayStation Move  Battery Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Using a Phillips #0 screwdriver, remove the four 10mm screws located on the back of the device.
    댓글 쓰기
  2. PlayStation Move  Battery Replacement: 2 단계, 이미지 2개 중 1개 PlayStation Move  Battery Replacement: 2 단계, 이미지 2개 중 2개
    • Insert the plastic opening tool at the indent.
    • Gently use a forward and backward motion to safely pop open the cover.
    • Using your hands to further pull it apart.
    댓글 쓰기
  3. PlayStation Move  Battery Replacement: 3 단계, 이미지 2개 중 1개 PlayStation Move  Battery Replacement: 3 단계, 이미지 2개 중 2개
    • Once the device is opened, lift the battery out of the black plastic holder.
    • Carefully pull the battery out and ensure that it's wires are still connected to the inside.
    댓글 쓰기
  4. PlayStation Move  Battery Replacement: 4 단계, 이미지 3개 중 1개 PlayStation Move  Battery Replacement: 4 단계, 이미지 3개 중 2개 PlayStation Move  Battery Replacement: 4 단계, 이미지 3개 중 3개
    • Using a Phillips head screwdriver, remove the 9mm screw located to the right of the battery, which is connected to the inner plastic frame.
    • Using the plastic opening tool carefully take out the grey cylindrical piece (vibrator) that is also attached to a wire.
    댓글 쓰기
  5. PlayStation Move  Battery Replacement: 5 단계, 이미지 2개 중 1개 PlayStation Move  Battery Replacement: 5 단계, 이미지 2개 중 2개
    • Gently pull out the small grey cylindrical piece (vibrator).
    • Removing this piece makes it easier to access the wire connection of the battery and remove it.
    댓글 쓰기
  6. PlayStation Move  Battery Replacement: 6 단계, 이미지 2개 중 1개 PlayStation Move  Battery Replacement: 6 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Using tweezers, remove the small piece with a cylindrical top that is located to the left of the inner plastic frame.
    댓글 쓰기
  7. PlayStation Move  Battery Replacement: 7 단계, 이미지 3개 중 1개 PlayStation Move  Battery Replacement: 7 단계, 이미지 3개 중 2개 PlayStation Move  Battery Replacement: 7 단계, 이미지 3개 중 3개
    • Using one hand to hold the device, and the other hand to squeeze the inner plastic frame.
    • Remove by squeezing the inner plastic frame, lift and pull it towards you.
    • While removing the frame, be extremely careful because it could damage the frame or the motherboard.
    댓글 쓰기
  8. PlayStation Move  Battery Replacement: 8 단계, 이미지 2개 중 1개 PlayStation Move  Battery Replacement: 8 단계, 이미지 2개 중 2개
    • Gently pull on the white piece connecting the battery and the connector.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 11명이 해당 안내서를 완성하였습니다.
작성자
13다른 기여자 명과 함께
Jenelle Mohammed
회원 가입일: 09/28/16
253 평판
안내서 1개를 작성함
USF Tampa, Team 3-3, Passmore Fall 2016 USF Tampa, Team 3-3, Passmore Fall 2016 회원
USFT-PASSMORE-F16S3G3
4 회원들
안내서 10개를 작성함
5가이드 댓글
When putting the plastic battery rig back in on my second time doing this, I bent one of the little plastic pins that fits into a hole in the PCB. Definitely want to be careful with that. To make it a bit easier, I unscrewed the bottom port PCB part of the way so I could take the bottom plastic housing and put the plastic battery rig in straight. It made it a lot easier.
Burke Cates - 답글 공유
No need to take out the motor, just use sharp tweezers and grab the connector (NOT the wires) and with small wiggling pull it out. Worked for mine.
crus - 답글 공유
Worked great! Thanks for this. I did not need to take out the black battery / motor piece. Tweezers worked great to remove and install the battery cable
Harry Skigis - 답글 공유
Any recommended online / physical store to buy new batteries for this because ifixit doesn’t have them?
[deleted] - 답글 공유
Je suis pas capable de coupler les manettes et quand j essaie de l ouvrir la lumière ne reste pas allumée. Sa se peut tu que les batteries sont finis. Je viens de l acheter usager
Rachelle Tremblay - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 36
지난 30일: 127
전체 시간: 17,516
