주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
PlayStation Move LED Light Replacement
필요한 것
  1. PlayStation Move LED Light Replacement, Battery: 1 단계, 이미지 3개 중 1개 PlayStation Move LED Light Replacement, Battery: 1 단계, 이미지 3개 중 2개 PlayStation Move LED Light Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Using a Phillips #0 screwdriver, remove the four 10mm screws located on the back of the device.
    댓글 쓰기
  2. PlayStation Move LED Light Replacement: 2 단계, 이미지 2개 중 1개 PlayStation Move LED Light Replacement: 2 단계, 이미지 2개 중 2개
    • Insert the plastic opening tool at the indent.
    • Gently use a forward and backward motion to safely pop open the cover.
    • Using your hands to further pull it apart.
    댓글 쓰기
  3. PlayStation Move LED Light Replacement: 3 단계, 이미지 2개 중 1개 PlayStation Move LED Light Replacement: 3 단계, 이미지 2개 중 2개
    • Once the device is opened, lift the battery out of the black plastic holder.
    • Carefully pull the battery out and ensure that it's wires are still connected to the inside.
    댓글 쓰기
  4. PlayStation Move LED Light Replacement: 4 단계, 이미지 3개 중 1개 PlayStation Move LED Light Replacement: 4 단계, 이미지 3개 중 2개 PlayStation Move LED Light Replacement: 4 단계, 이미지 3개 중 3개
    • Using a Phillips head screwdriver, remove the 9mm screw located to the right of the battery, which is connected to the inner plastic frame.
    • Using the plastic opening tool carefully take out the grey cylindrical piece (vibrator) that is also attached to a wire.
    댓글 쓰기
  5. PlayStation Move LED Light Replacement: 5 단계, 이미지 2개 중 1개 PlayStation Move LED Light Replacement: 5 단계, 이미지 2개 중 2개
    • Gently pull out the small grey cylindrical piece (vibrator).
    • Removing this piece makes it easier to access the wire connection of the battery and remove it.
    댓글 쓰기
  6. PlayStation Move LED Light Replacement: 6 단계, 이미지 2개 중 1개 PlayStation Move LED Light Replacement: 6 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Using tweezers, remove the small piece with a cylindrical top that is located to the left of the inner plastic frame.
    댓글 쓰기
  7. PlayStation Move LED Light Replacement: 7 단계, 이미지 3개 중 1개 PlayStation Move LED Light Replacement: 7 단계, 이미지 3개 중 2개 PlayStation Move LED Light Replacement: 7 단계, 이미지 3개 중 3개
    • Using one hand to hold the device, and the other hand to squeeze the inner plastic frame.
    • Remove by squeezing the inner plastic frame, lift and pull it towards you.
    • While removing the frame, be extremely careful because it could damage the frame or the motherboard.
    댓글 쓰기
  8. PlayStation Move LED Light Replacement: 8 단계, 이미지 2개 중 1개 PlayStation Move LED Light Replacement: 8 단계, 이미지 2개 중 2개
    • Gently pull on the white piece connecting the battery and the connector.
    댓글 쓰기
  9. PlayStation Move LED Light Replacement, Motherboard: 9 단계, 이미지 3개 중 1개 PlayStation Move LED Light Replacement, Motherboard: 9 단계, 이미지 3개 중 2개 PlayStation Move LED Light Replacement, Motherboard: 9 단계, 이미지 3개 중 3개
    • Remove the five 1.2 mm screws from upper portion of the controller.
    • If you are replacing the trigger button, continue to step 13.
    댓글 쓰기
  10. PlayStation Move LED Light Replacement: 10 단계, 이미지 2개 중 1개 PlayStation Move LED Light Replacement: 10 단계, 이미지 2개 중 2개
    • Remove the two 1.2mm Phillips #1 screws.
    댓글 쓰기
  11. PlayStation Move LED Light Replacement: 11 단계, 이미지 3개 중 1개 PlayStation Move LED Light Replacement: 11 단계, 이미지 3개 중 2개 PlayStation Move LED Light Replacement: 11 단계, 이미지 3개 중 3개
    • Cautiously remove the circular white piece at the top without removing the LED inside.
    댓글 쓰기
  12. PlayStation Move LED Light Replacement: 12 단계, 이미지 3개 중 1개 PlayStation Move LED Light Replacement: 12 단계, 이미지 3개 중 2개 PlayStation Move LED Light Replacement: 12 단계, 이미지 3개 중 3개
    • Remove the blue strip that is connected to the trigger button from the motherboard.
    • Be careful to gently detach it from the motherboard. The strip may rip if too much strength is applied.
    댓글 쓰기
  13. PlayStation Move LED Light Replacement: 13 단계, 이미지 2개 중 1개 PlayStation Move LED Light Replacement: 13 단계, 이미지 2개 중 2개
    • Remove the trigger button from the controller.
    댓글 쓰기
  14. PlayStation Move LED Light Replacement: 14 단계, 이미지 3개 중 1개 PlayStation Move LED Light Replacement: 14 단계, 이미지 3개 중 2개 PlayStation Move LED Light Replacement: 14 단계, 이미지 3개 중 3개
    • Remove the LED light by removing the white strip.
    • If you are replacing the LED light, continue to Step 17.
    댓글 쓰기
  15. PlayStation Move LED Light Replacement: 15 단계, 이미지 2개 중 1개 PlayStation Move LED Light Replacement: 15 단계, 이미지 2개 중 2개
    • Remove the motherboard from the plastic case.
    댓글 쓰기
  16. PlayStation Move LED Light Replacement, LED Light: 16 단계, 이미지 2개 중 1개 PlayStation Move LED Light Replacement, LED Light: 16 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Insert tweezers between the LED case and the LED clear plastic cover.
    • Lift the edge of the LED clear cover clip to be able to remove the cover.
    • Repeat the previous step to the other side.
    • Remove the LED cover.
    댓글 쓰기
  17. PlayStation Move LED Light Replacement: 17 단계, 이미지 2개 중 1개 PlayStation Move LED Light Replacement: 17 단계, 이미지 2개 중 2개
    • Remove the LED board using a blue opening tool to lift the board.
    • After the board is loose, remove the LED board.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Maritza Martinez
회원 가입일: 09/28/16
155 평판
안내서 1개를 작성함
USF Tampa, Team 3-3, Passmore Fall 2016 USF Tampa, Team 3-3, Passmore Fall 2016 회원
USFT-PASSMORE-F16S3G3
4 회원들
안내서 10개를 작성함
5가이드 댓글
Okay, going to try this. Do I have to solder the white strip back onto the board?
randallrigdonjr - 답글 공유
did you ever get this done? need to know the same.
[deleted] - 답글 공유
très clair, mais où trouver une led ? et en enlevant le cable de la led, il faut le dessourder, non ?
Pierrot - 답글 공유
This is BEYOND useless without the information as to where to get the LED unit itself. It's not a standard LED board I can find anywhere.
Also, on the PS3 Move controller the cable from the main board to the LED is soldered both ends and doesn't simply lift away from the circuit.
As to the "beyond useless" comment, this isn't meant to be directed towards the kind people who have spent their time to help others with their knowledge and, their LED cable may have simply lifted away from the board if the Move controller was the later PS4 model, I don't know, I haven't pulled a PS4 Move controller apart (yet).
The guide however would be so much better with that one tiny bit of information, where can I find the LED module and the 1039 number on the LED board itself is of no help in my search.
I stripped my controller down before I found the link to this article (qualifications in electronics), my main need is identifying the faulty LED module so I can replace it.
Leo Anon - 답글 공유
Sorry, how do I reconnect the white cable I've just cut away from the circuit board solder joints as you've done?
Butchers!
SERIOUSLY??
No, I'm NOT stupid enough to cut cables and magically think they reconnect using the reverse disassembly instructions as suggested (just poke them in like a magician and they magically connect themselves, if only). Someone needs to rethink their idea of an article to "HELP" people.
Leo Anon - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 9
지난 30일: 75
전체 시간: 5,582
