주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
PlayStation Move Trigger Button Replacement
필요한 것
  1. PlayStation Move Trigger Button Replacement, Battery: 1 단계, 이미지 3개 중 1개 PlayStation Move Trigger Button Replacement, Battery: 1 단계, 이미지 3개 중 2개 PlayStation Move Trigger Button Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Using a Phillips #0 screwdriver, remove the four 10mm screws located on the back of the device.
    댓글 쓰기
  2. PlayStation Move Trigger Button Replacement: 2 단계, 이미지 2개 중 1개 PlayStation Move Trigger Button Replacement: 2 단계, 이미지 2개 중 2개
    • Insert the plastic opening tool at the indent.
    • Gently use a forward and backward motion to safely pop open the cover.
    • Using your hands to further pull it apart.
    댓글 쓰기
  3. PlayStation Move Trigger Button Replacement: 3 단계, 이미지 2개 중 1개 PlayStation Move Trigger Button Replacement: 3 단계, 이미지 2개 중 2개
    • Once the device is opened, lift the battery out of the black plastic holder.
    • Carefully pull the battery out and ensure that it's wires are still connected to the inside.
    댓글 쓰기
  4. PlayStation Move Trigger Button Replacement: 4 단계, 이미지 3개 중 1개 PlayStation Move Trigger Button Replacement: 4 단계, 이미지 3개 중 2개 PlayStation Move Trigger Button Replacement: 4 단계, 이미지 3개 중 3개
    • Using a Phillips head screwdriver, remove the 9mm screw located to the right of the battery, which is connected to the inner plastic frame.
    • Using the plastic opening tool carefully take out the grey cylindrical piece (vibrator) that is also attached to a wire.
    댓글 쓰기
  5. PlayStation Move Trigger Button Replacement: 5 단계, 이미지 2개 중 1개 PlayStation Move Trigger Button Replacement: 5 단계, 이미지 2개 중 2개
    • Gently pull out the small grey cylindrical piece (vibrator).
    • Removing this piece makes it easier to access the wire connection of the battery and remove it.
    댓글 쓰기
  6. PlayStation Move Trigger Button Replacement: 6 단계, 이미지 2개 중 1개 PlayStation Move Trigger Button Replacement: 6 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Using tweezers, remove the small piece with a cylindrical top that is located to the left of the inner plastic frame.
    댓글 쓰기
  7. PlayStation Move Trigger Button Replacement: 7 단계, 이미지 3개 중 1개 PlayStation Move Trigger Button Replacement: 7 단계, 이미지 3개 중 2개 PlayStation Move Trigger Button Replacement: 7 단계, 이미지 3개 중 3개
    • Using one hand to hold the device, and the other hand to squeeze the inner plastic frame.
    • Remove by squeezing the inner plastic frame, lift and pull it towards you.
    • While removing the frame, be extremely careful because it could damage the frame or the motherboard.
    댓글 쓰기
  8. PlayStation Move Trigger Button Replacement: 8 단계, 이미지 2개 중 1개 PlayStation Move Trigger Button Replacement: 8 단계, 이미지 2개 중 2개
    • Gently pull on the white piece connecting the battery and the connector.
    댓글 쓰기
  9. PlayStation Move Trigger Button Replacement, Motherboard: 9 단계, 이미지 3개 중 1개 PlayStation Move Trigger Button Replacement, Motherboard: 9 단계, 이미지 3개 중 2개 PlayStation Move Trigger Button Replacement, Motherboard: 9 단계, 이미지 3개 중 3개
    • Remove the five 1.2 mm screws from upper portion of the controller.
    • If you are replacing the trigger button, continue to step 13.
    댓글 쓰기
  10. PlayStation Move Trigger Button Replacement: 10 단계, 이미지 2개 중 1개 PlayStation Move Trigger Button Replacement: 10 단계, 이미지 2개 중 2개
    • Remove the two 1.2mm Phillips #1 screws.
    댓글 쓰기
  11. PlayStation Move Trigger Button Replacement: 11 단계, 이미지 3개 중 1개 PlayStation Move Trigger Button Replacement: 11 단계, 이미지 3개 중 2개 PlayStation Move Trigger Button Replacement: 11 단계, 이미지 3개 중 3개
    • Cautiously remove the circular white piece at the top without removing the LED inside.
    댓글 쓰기
  12. PlayStation Move Trigger Button Replacement: 12 단계, 이미지 3개 중 1개 PlayStation Move Trigger Button Replacement: 12 단계, 이미지 3개 중 2개 PlayStation Move Trigger Button Replacement: 12 단계, 이미지 3개 중 3개
    • Remove the blue strip that is connected to the trigger button from the motherboard.
    • Be careful to gently detach it from the motherboard. The strip may rip if too much strength is applied.
    댓글 쓰기
  13. PlayStation Move Trigger Button Replacement: 13 단계, 이미지 2개 중 1개 PlayStation Move Trigger Button Replacement: 13 단계, 이미지 2개 중 2개
    • Remove the trigger button from the controller.
    댓글 쓰기
  14. PlayStation Move Trigger Button Replacement: 14 단계, 이미지 3개 중 1개 PlayStation Move Trigger Button Replacement: 14 단계, 이미지 3개 중 2개 PlayStation Move Trigger Button Replacement: 14 단계, 이미지 3개 중 3개
    • Remove the LED light by removing the white strip.
    • If you are replacing the LED light, continue to Step 17.
    댓글 쓰기
  15. PlayStation Move Trigger Button Replacement: 15 단계, 이미지 2개 중 1개 PlayStation Move Trigger Button Replacement: 15 단계, 이미지 2개 중 2개
    • Remove the motherboard from the plastic case.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Abdulaziz Refaei
회원 가입일: 09/28/16
183 평판
안내서 1개를 작성함
USF Tampa, Team 3-3, Passmore Fall 2016 USF Tampa, Team 3-3, Passmore Fall 2016 회원
USFT-PASSMORE-F16S3G3
4 회원들
안내서 10개를 작성함
3가이드 댓글
This disassembly is destructive (namely to the LED connector as it is soldered to the main board) and has many unnecessary steps for simply replacing the trigger button assembly. It also says no parts are required but you would clearly need replacement trigger parts.
Peter Miller - 답글 공유
this did not help at all
lucas ainsworth - 답글 공유
I have searched a lot on the internet and cannot find any parts for it.
Dormius Oksivox - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 16
지난 30일: 52
전체 시간: 3,890
