주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
PlayStation Optical Drive Replacement
필요한 것
  1. PlayStation Optical Drive Replacement, Open the Console: 1 단계, 이미지 1개 중 1개
    • Before you begin, make sure the console is turned off and unplugged.
    • Turn the console upside down and remove the five 15.8 mm-long Phillips #1 screws.
    댓글 쓰기
  2. PlayStation Optical Drive Replacement: 2 단계, 이미지 2개 중 1개 PlayStation Optical Drive Replacement: 2 단계, 이미지 2개 중 2개
    • While holding the top and bottom halves of the console together, flip the console back over. Lift the top cover straight up to remove it.
    댓글 쓰기
  3. PlayStation Optical Drive Replacement, Remove the Optical Drive: 3 단계, 이미지 2개 중 1개 PlayStation Optical Drive Replacement, Remove the Optical Drive: 3 단계, 이미지 2개 중 2개
    • Pull the optical drive power cable straight up and out of its socket on the motherboard to disconnect it.
    댓글 쓰기
  4. PlayStation Optical Drive Replacement: 4 단계, 이미지 3개 중 1개 PlayStation Optical Drive Replacement: 4 단계, 이미지 3개 중 2개 PlayStation Optical Drive Replacement: 4 단계, 이미지 3개 중 3개
    • Use the flat end of a spudger to lift up and unlock one side of the data cable's connector on the motherboard. Repeat this step on the other side of the connector.
    • You'll hear a faint click noise when unlocking the connector. Make sure not to apply too much pressure when lifting up on the connector with the spudger, or else damage may result.
    • Gently pull the optical drive data cable straight up and out of its socket on the motherboard to disconnect it.
    댓글 쓰기
  5. PlayStation Optical Drive Replacement: 5 단계, 이미지 2개 중 1개 PlayStation Optical Drive Replacement: 5 단계, 이미지 2개 중 2개
    • Lift the optical drive straight up to remove it.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 56명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Craig Lloyd
회원 가입일: 02/10/16
42,897 평판
안내서 82개를 작성함
5가이드 댓글
Laser Drive Models
SCPH-100x : KSM-440AAM and KSM-440ACM
SCPH-550x-700x : KSM-440ADM
SCPH-750x-900x : KSM-440AEM
SCPH-10x : KSM-440BAM
Chances are most, if not all of the original AAM and ACM lasers are worn out.
Some vendors still carry an supposed original KSM-440BAM laser unit only.
I could not make this laser work in a SCPH-1001 unit, even after the transfer of parts.
I heard a rumor of spacers and motherboard adjustment.
This: https://web.archive.org/web/201010090109...
PU-8 test point: CL708, voltage reading to ground without disk - 1.7 volts DC, voltage reading with disk 1.85 volts DC.
Very fine adjustment… I have yet to try this step. Has anyone?
What about spacers? Do I need these?
You must transfer the rubber grommets and the plastic laser cover from the old laser to the new.
If you don’t, the new laser will be too large for the SCPH-1001 chassis.
leafybye - 답글 공유
What about model SCPH-5501?
janis Nasuta - 답글 공유
Will a KSM-440BAM optical drive from a scph-1001 ps1 work with a scph-1001 ps1 that had a KSM-440ACM optical drive?
The invader 2 - 답글 공유
Hello! Has anyone had success with replacing the optical drive on a 1001?
If so, which model of drive was used?
John Reeves - 답글 공유
which optical drive do you recommend on SCPH-1002?
Juan YT - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 15
지난 7일: 120
지난 30일: 596
전체 시간: 76,982
