주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
PlayStation VR LED Light Tracker Replacement
필요한 것
    1. PlayStation VR LED Light Tracker Replacement, LED Light Tracker: 1 단계, 이미지 3개 중 1개 PlayStation VR LED Light Tracker Replacement, LED Light Tracker: 1 단계, 이미지 3개 중 2개 PlayStation VR LED Light Tracker Replacement, LED Light Tracker: 1 단계, 이미지 3개 중 3개
      • Peel back the rubber covering around the lenses to remove the surrounding plastic eyepieces.
      댓글 쓰기
    2. PlayStation VR LED Light Tracker Replacement: 2 단계, 이미지 2개 중 1개 PlayStation VR LED Light Tracker Replacement: 2 단계, 이미지 2개 중 2개
      • Unscrew four 13 mm screws with a PH #000 screwdriver.
      댓글 쓰기
    3. PlayStation VR LED Light Tracker Replacement: 3 단계, 이미지 2개 중 1개 PlayStation VR LED Light Tracker Replacement: 3 단계, 이미지 2개 중 2개
      • Using the plastic opening tool, carefully pry the white plastic panel free from the side of the headset. Repeat this action for the opposite side.
      댓글 쓰기
    4. PlayStation VR LED Light Tracker Replacement: 4 단계, 이미지 3개 중 1개 PlayStation VR LED Light Tracker Replacement: 4 단계, 이미지 3개 중 2개 PlayStation VR LED Light Tracker Replacement: 4 단계, 이미지 3개 중 3개
      • Use the plastic opening tool to pry the top white plastic panel free from the headset.
      • Do not try to remove the bottom plastic panel. There is a screw attaching it that must be removed first.
      • There may be a small amount of adhesive attaching the top panel to the headset, in which case you may need to use a bit more force to remove the panel.
      댓글 쓰기
    5. PlayStation VR LED Light Tracker Replacement: 5 단계, 이미지 1개 중 1개
      • Flip the headset over.
      • Using a PH #000, unscrew the 7 mm screw found on the bottom of the headset.
      댓글 쓰기
    6. PlayStation VR LED Light Tracker Replacement: 6 단계, 이미지 3개 중 1개 PlayStation VR LED Light Tracker Replacement: 6 단계, 이미지 3개 중 2개 PlayStation VR LED Light Tracker Replacement: 6 단계, 이미지 3개 중 3개
      • Using the plastic opening tool, pry the bottom white plastic panel loose and remove it from the headset.
      • There is adhesive attaching the panel to the headset, in which case it will take more force to remove the panel.
      댓글 쓰기
    7. PlayStation VR LED Light Tracker Replacement: 7 단계, 이미지 3개 중 1개 PlayStation VR LED Light Tracker Replacement: 7 단계, 이미지 3개 중 2개 PlayStation VR LED Light Tracker Replacement: 7 단계, 이미지 3개 중 3개
      • Unscrew the two 7 mm screws from the top of the headset.
      댓글 쓰기
    8. PlayStation VR LED Light Tracker Replacement: 8 단계, 이미지 3개 중 1개 PlayStation VR LED Light Tracker Replacement: 8 단계, 이미지 3개 중 2개 PlayStation VR LED Light Tracker Replacement: 8 단계, 이미지 3개 중 3개
      • Using your fingers, carefully pry the black front panel free from the headset.
      • We recommend that you start the removal from the sides by pulling them forward.
      • There is adhesive holding the front panel in place, which means you will need a bit of extra force to remove it.
      댓글 쓰기
    9. PlayStation VR LED Light Tracker Replacement: 9 단계, 이미지 1개 중 1개
      • Unscrew the four silver 6 mm screws in each corner using a PH #000 screwdriver.
      댓글 쓰기
    10. PlayStation VR LED Light Tracker Replacement: 10 단계, 이미지 3개 중 1개 PlayStation VR LED Light Tracker Replacement: 10 단계, 이미지 3개 중 2개 PlayStation VR LED Light Tracker Replacement: 10 단계, 이미지 3개 중 3개
      • Lift the small silver latch attaching the ZIF (zero insertion force) connector to the circuit board.
      • Carefully pull the end of the white ribbon connector from its slot.
      • Be careful not to damage or dirty the ribbon connector.
      댓글 쓰기
    11. PlayStation VR LED Light Tracker Replacement: 11 단계, 이미지 2개 중 1개 PlayStation VR LED Light Tracker Replacement: 11 단계, 이미지 2개 중 2개
      • Unhitch the yellow led connector ribbon and move it aside.
      댓글 쓰기
    12. PlayStation VR LED Light Tracker Replacement: 12 단계, 이미지 3개 중 1개 PlayStation VR LED Light Tracker Replacement: 12 단계, 이미지 3개 중 2개 PlayStation VR LED Light Tracker Replacement: 12 단계, 이미지 3개 중 3개
      • Carefully pry the black plastic piece attaching the yellow ribbon to the headset away from the green circuit board.
      • Remove the yellow LED ribbons and black plastic connecting piece from the headset.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Sarah Shand
회원 가입일: 02/20/17
1,996 평판
안내서 7개를 작성함
USF Tampa, Team S3-G1, Sullivan Spring 2017 USF Tampa, Team S3-G1, Sullivan Spring 2017 회원
USFT-SULLIVAN-S17S3G1
3 회원들
안내서 64개를 작성함
1가이드 댓글
where can I buy the LED lights for it??
Jordi - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 58
전체 시간: 4,748
