주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
PlayStation VR Processor Unit Cooling Fan Replacement
필요한 것
    1. PlayStation VR Processor Unit Cooling Fan Replacement, Processor Unit Cooling Fan: 1 단계, 이미지 3개 중 1개 PlayStation VR Processor Unit Cooling Fan Replacement, Processor Unit Cooling Fan: 1 단계, 이미지 3개 중 2개 PlayStation VR Processor Unit Cooling Fan Replacement, Processor Unit Cooling Fan: 1 단계, 이미지 3개 중 3개
      • On one side of the console (the side adjacent to the fan vent), there will be two 6 mm screws. Unscrew them with a PH #000 screwdriver.
      댓글 쓰기
    2. PlayStation VR Processor Unit Cooling Fan Replacement: 2 단계, 이미지 3개 중 1개 PlayStation VR Processor Unit Cooling Fan Replacement: 2 단계, 이미지 3개 중 2개 PlayStation VR Processor Unit Cooling Fan Replacement: 2 단계, 이미지 3개 중 3개
      • Press and slide the side panel (it will have the two ports) back to reveal an additional 6 mm screw.
      • Unscrew the 6mm screw with a PH #000 screwdriver.
      댓글 쓰기
    3. PlayStation VR Processor Unit Cooling Fan Replacement: 3 단계, 이미지 2개 중 1개 PlayStation VR Processor Unit Cooling Fan Replacement: 3 단계, 이미지 2개 중 2개
      • Slide the panel back into place.
      댓글 쓰기
    4. PlayStation VR Processor Unit Cooling Fan Replacement: 4 단계, 이미지 3개 중 1개 PlayStation VR Processor Unit Cooling Fan Replacement: 4 단계, 이미지 3개 중 2개 PlayStation VR Processor Unit Cooling Fan Replacement: 4 단계, 이미지 3개 중 3개
      • Using a plastic opening tool, carefully pry the panel from the main console to reveal the HDMI ports.
      • You will probably need to lift it on both sides in order for the panel to come loose.
      댓글 쓰기
    5. PlayStation VR Processor Unit Cooling Fan Replacement: 5 단계, 이미지 1개 중 1개
      • Turn the console over.
      • Unscrew the two 9 mm screws with a PH #000 screwdriver.
      댓글 쓰기
    6. PlayStation VR Processor Unit Cooling Fan Replacement: 6 단계, 이미지 2개 중 1개 PlayStation VR Processor Unit Cooling Fan Replacement: 6 단계, 이미지 2개 중 2개
      • With the plastic opening tool, carefully pry the console shell panel free and lift it away.
      댓글 쓰기
    7. PlayStation VR Processor Unit Cooling Fan Replacement: 7 단계, 이미지 2개 중 1개 PlayStation VR Processor Unit Cooling Fan Replacement: 7 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Using tweezers, carefully pull the multi colored bundled cable from its port connecting the fan to the console.
      • Carefully lift the fan and its wiring from the device.
      • Be mindful of damaging the wires.
      • Take care to keep your fingers away from the fan blades.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 8명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Sarah Shand
회원 가입일: 02/20/17
1,996 평판
안내서 7개를 작성함
USF Tampa, Team S3-G1, Sullivan Spring 2017 USF Tampa, Team S3-G1, Sullivan Spring 2017 회원
USFT-SULLIVAN-S17S3G1
3 회원들
안내서 64개를 작성함
4가이드 댓글
Where do I get a replacement fan tho?
Ponos King - 답글 공유
I think is a 3x3 cm fan, alliexpres has some, but what voltage?
crus - 답글 공유
5V is what i have read
Ethan Amos - 답글 공유
Reference for fan when I have replaced mine : DELTA ELECTRONICS MODEL : ASB0305MA-01 DC 5V 0.19A
herossuperman - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 7
지난 30일: 75
전체 시간: 10,817
