주요 콘텐츠로 건너뛰기
Pocophone F1 Back Cover Removal
필요한 것
  1. Pocophone F1 Back Cover Removal, Remove the SIM tray: 1 단계, 이미지 1/3 Pocophone F1 Back Cover Removal, Remove the SIM tray: 1 단계, 이미지 2/3 Pocophone F1 Back Cover Removal, Remove the SIM tray: 1 단계, 이미지 3/3
    • Before you begin, switch off your phone.
    • Insert a SIM eject tool or a paperclip into the small hole on the SIM card tray on the left edge of the phone.
    • Press firmly to eject the tray.
    • Remove the SIM card tray.
    • When reinserting the cards, make sure to properly orient them in the tray.
  2. Pocophone F1 Back Cover Removal, Unfasten the back cover screws: 2 단계, 이미지 1/1
    • Remove the two 2.7 mm-long Torx T3 screws from the bottom edge of your phone.
  3. Pocophone F1 Back Cover Removal, Insert an opening tool: 3 단계, 이미지 1/3 Pocophone F1 Back Cover Removal, Insert an opening tool: 3 단계, 이미지 2/3 Pocophone F1 Back Cover Removal, Insert an opening tool: 3 단계, 이미지 3/3
    • Insert an opening tool between the screen and the back cover at the bottom edge of the screen.
    • Slide the opening tool to the bottom right corner to release the plastic clips holding the back cover in place.
  4. Pocophone F1 Back Cover Removal, Release the clips: 4 단계, 이미지 1/3 Pocophone F1 Back Cover Removal, Release the clips: 4 단계, 이미지 2/3 Pocophone F1 Back Cover Removal, Release the clips: 4 단계, 이미지 3/3
    • Slide the opening tool around the bottom right corner.
    • Slide the opening tool along the right edge of the Pocophone F1 to release the plastic clips.
  5. Pocophone F1 Back Cover Removal: 5 단계, 이미지 1/2 Pocophone F1 Back Cover Removal: 5 단계, 이미지 2/2
    • Slide the opening tool along the top edge of the phone to release the plastic clips holding the back cover in place.
  6. Pocophone F1 Back Cover Removal: 6 단계, 이미지 1/3 Pocophone F1 Back Cover Removal: 6 단계, 이미지 2/3 Pocophone F1 Back Cover Removal: 6 단계, 이미지 3/3
    • Slide the opening tool along the left edge of the phone to release the remaining plastic clips.
    • Try not to remove the back cover all the way yet, the flex cable of the fingerprint sensor is still connected to the motherboard.
  7. Pocophone F1 Back Cover Removal: 7 단계, 이미지 1/3 Pocophone F1 Back Cover Removal: 7 단계, 이미지 2/3 Pocophone F1 Back Cover Removal: 7 단계, 이미지 3/3
    • Carefully fold the phone assembly to the left side of the back cover like you'd open a book page.
    • Avoid tensioning the fingerprint flex cable during this procedure.
  8. Pocophone F1 Back Cover Removal, Unfasten screws: 8 단계, 이미지 1/1
    • Remove the ten 3.2 mm-long Phillips screws.
  9. Pocophone F1 Back Cover Removal: 9 단계, 이미지 1/3 Pocophone F1 Back Cover Removal: 9 단계, 이미지 2/3 Pocophone F1 Back Cover Removal: 9 단계, 이미지 3/3
    • Slide an opening pick under the bottom left corner of the motherboard cover.
    • Slide the opening pick around the corner and along the left edge of the motherboard cover to release the plastic clips holding it in place.
    • Use the opening pick to pry up the motherboard cover.
  10. Pocophone F1 Back Cover Removal, Remove the motherboard cover: 10 단계, 이미지 1/2 Pocophone F1 Back Cover Removal, Remove the motherboard cover: 10 단계, 이미지 2/2
    • Remove the motherboard cover.
  11. Pocophone F1 Back Cover Removal, Remove the back cover: 11 단계, 이미지 1/3 Pocophone F1 Back Cover Removal, Remove the back cover: 11 단계, 이미지 2/3 Pocophone F1 Back Cover Removal, Remove the back cover: 11 단계, 이미지 3/3
    • Use the flat end of a spudger to pry up and disconnect the fingerprint flex connector.
    • Remove the back cover.
결론
Removal didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
다른 9명이 해당 안내서를 완성하였습니다.
Dominik Schnabelrauch
회원 가입일: 11/23/16
210,026 평판
안내서 682개 작성하였습니다
iFixit iFixit 회원
Staff
141 회원들
안내서 17,895개 작성하였습니다
댓글 한 개
Thank for the help
Ellusion - 답글
댓글 쓰기
조회 통계:
24 시간 전: 9
7일 전: 43
30일 전: 211
전체 시간: 9,715
