주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Polaroid Automatic 100 Bellows Replacement
필요한 것
    1. Polaroid Automatic 100 Bellows Replacement, Bellows: 1 단계, 이미지 3개 중 1개 Polaroid Automatic 100 Bellows Replacement, Bellows: 1 단계, 이미지 3개 중 2개 Polaroid Automatic 100 Bellows Replacement, Bellows: 1 단계, 이미지 3개 중 3개
      • Fully extend the bellows by lifting the #1 lever.
      • Remove the camera cover in order to make the camera easier to work with.
      • When collapsing bellows, press down on the metal frame above the bellows.
      댓글 쓰기
    2. Polaroid Automatic 100 Bellows Replacement: 2 단계, 이미지 1개 중 1개
      • Peel the two battery cable tabs off of the bellows.
      댓글 쓰기
    3. Polaroid Automatic 100 Bellows Replacement: 3 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      Flathead 3/32" or 2.5 mm Screwdriver
      $5.49
      • Remove one 15.5 mm flat head screw, with a 2.5 flathead screwdriver.
      • Remove two 2 mm flat head screws, with a 2.5 flathead screwdriver. Then carefully remove the cable cover.
      • Use the focus bar to extend bellows even further to access screws easier with the screwdriver.
      댓글 쓰기
    4. Polaroid Automatic 100 Bellows Replacement: 4 단계, 이미지 2개 중 1개 Polaroid Automatic 100 Bellows Replacement: 4 단계, 이미지 2개 중 2개
      • Open the back cover by pushing the lever on the bottom towards the left.
      댓글 쓰기
    5. Polaroid Automatic 100 Bellows Replacement: 5 단계, 이미지 1개 중 1개
      • Remove the four 3 mm screws, which are attached to the lens of the camera, using a Phillips #0 screwdriver.
      • To make the screws easily accessible, close the bellows by pushing on the metal frame.
      • When reassembling, orient the camera so that screws are screwed in downward and stay in place.
      댓글 쓰기
    6. Polaroid Automatic 100 Bellows Replacement: 6 단계, 이미지 1개 중 1개
      • Carefully use a classic wide metal spudger to bend the tabs of the bellows.
      댓글 쓰기
    7. Polaroid Automatic 100 Bellows Replacement: 7 단계, 이미지 2개 중 1개 Polaroid Automatic 100 Bellows Replacement: 7 단계, 이미지 2개 중 2개
      • Pull the bellow tabs back with long needle nose pliers.
      • Remove the bellows.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Katie Miller
회원 가입일: 04/14/15
680 평판
안내서 5개를 작성함
Cal Poly, Team 4-3, Maness Spring 2015 Cal Poly, Team 4-3, Maness Spring 2015 회원
CPSU-MANESS-S15S4G3
4 회원들
안내서 59개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 12
지난 30일: 38
전체 시간: 2,790
