주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Polaroid Automatic 100 Bottom Frame Spring Replacement
필요한 것
    1. Polaroid Automatic 100 Bottom Frame Spring Replacement, Bottom Frame Spring Replacement: 1 단계, 이미지 3개 중 1개 Polaroid Automatic 100 Bottom Frame Spring Replacement, Bottom Frame Spring Replacement: 1 단계, 이미지 3개 중 2개 Polaroid Automatic 100 Bottom Frame Spring Replacement, Bottom Frame Spring Replacement: 1 단계, 이미지 3개 중 3개
      • Fully extend the bellows to prevent collapse using the #1 tab.
      • Remove the camera cover in order to make the camera easier to work with.
      • When collapsing bellows, press down on the metal frame above the bellows.
      댓글 쓰기
    2. Polaroid Automatic 100 Bottom Frame Spring Replacement: 2 단계, 이미지 1개 중 1개
      • Remove the Phillips #0 6mm screw on the shutter mount and the washers using a size 5 nut driver.
      댓글 쓰기
    3. Polaroid Automatic 100 Bottom Frame Spring Replacement: 3 단계, 이미지 1개 중 1개
      • Unscrew the 4.5 mm Phillips screw on the right with a Phillips #0 Screwdriver.
      댓글 쓰기
    4. Polaroid Automatic 100 Bottom Frame Spring Replacement: 4 단계, 이미지 3개 중 1개 Polaroid Automatic 100 Bottom Frame Spring Replacement: 4 단계, 이미지 3개 중 2개 Polaroid Automatic 100 Bottom Frame Spring Replacement: 4 단계, 이미지 3개 중 3개
      • Remove the spring from the shutter mount.
      • The hooks on the ends of the spring within the shutter mount may recoil when being removed, and may be sharp enough to puncture skin.
      • When reassembling, getting the smaller screw on the right hand side can be challenging. It may be helpful to tip the camera upside down so that gravity helps the screw fall into place.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Katie Miller
회원 가입일: 04/14/15
680 평판
안내서 5개를 작성함
Cal Poly, Team 4-3, Maness Spring 2015 Cal Poly, Team 4-3, Maness Spring 2015 회원
CPSU-MANESS-S15S4G3
4 회원들
안내서 16개를 작성함
2가이드 댓글
Thank you so very much!!!
You saved my camera and my sanity!!!!
CAROL HOLDER - 답글 공유
Has anyone ever had to replace their bellows with a new one? If so, where do I get one from?
sbenite - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 13
지난 30일: 40
전체 시간: 1,579
