주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Polaroid Flash Unit Shell Replacement
필요한 것
  1. Polaroid Flash Unit Shell Replacement, Before you begin: 1 단계, 이미지 1개 중 1개
    • If you have any film left, take some photos! Then remove the cartridge. Disassembly will expose any leftover film.
    • Unplug all cables from your camera.
    댓글 쓰기
  2. Polaroid Flash Unit Shell Replacement, Open your camera: 2 단계, 이미지 2개 중 1개 Polaroid Flash Unit Shell Replacement, Open your camera: 2 단계, 이미지 2개 중 2개
    • Fully open the flash unit at the front of your camera.
    댓글 쓰기
  3. Polaroid Flash Unit Shell Replacement, Remove the screw cover: 3 단계, 이미지 3개 중 1개 Polaroid Flash Unit Shell Replacement, Remove the screw cover: 3 단계, 이미지 3개 중 2개 Polaroid Flash Unit Shell Replacement, Remove the screw cover: 3 단계, 이미지 3개 중 3개
    • Slide the tip of an opening pick under the right edge of the screw cover, near the flash.
    • Leave the pick inserted under the cover for the next step.
    댓글 쓰기
  4. Polaroid Flash Unit Shell Replacement: 4 단계, 이미지 3개 중 1개 Polaroid Flash Unit Shell Replacement: 4 단계, 이미지 3개 중 2개 Polaroid Flash Unit Shell Replacement: 4 단계, 이미지 3개 중 3개
    • Slide the cover towards the flash to release the clips securing it.
    • Your pick might fall out—that's fine.
    • Pull the cover straight away from the camera and remove it.
    댓글 쓰기
  5. Polaroid Flash Unit Shell Replacement, Remove the flash unit shell screws: 5 단계, 이미지 3개 중 1개 Polaroid Flash Unit Shell Replacement, Remove the flash unit shell screws: 5 단계, 이미지 3개 중 2개 Polaroid Flash Unit Shell Replacement, Remove the flash unit shell screws: 5 단계, 이미지 3개 중 3개
    • Hold the flash unit open with one hand.
    • With your free hand, use a Phillips screwdriver to remove the three 5.9 mm‑long screws securing the flash unit shell.
    댓글 쓰기
  6. Polaroid Flash Unit Shell Replacement, Remove the flash unit shell: 6 단계, 이미지 3개 중 1개 Polaroid Flash Unit Shell Replacement, Remove the flash unit shell: 6 단계, 이미지 3개 중 2개 Polaroid Flash Unit Shell Replacement, Remove the flash unit shell: 6 단계, 이미지 3개 중 3개
    • Fully close the flash unit for a better grip on the shell.
    • Secure the camera with one hand, and firmly grip the flash unit shell with the other.
    • Lift the right edge of the shell (the side closest to the charging port) to release the clips securing it.
    • You should feel and hear "clicks" as the clips release.
    • Pull the shell up and away from the camera to remove it.
    • During reassembly, put the shell in place and push down firmly to engage the clips.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
1다른 기여자 명과 함께
Spencer Day
회원 가입일: 09/14/22
194,581 평판
안내서 1,243개를 작성함
iFixit iFixit 회원
Staff
122 회원들
안내서 26,572개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 26
전체 시간: 382
