주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Polaroid LCD-0700P Case Replacement
필요한 것
    1. Polaroid LCD-0700P Case Replacement, Case: 1 단계, 이미지 2개 중 1개 Polaroid LCD-0700P Case Replacement, Case: 1 단계, 이미지 2개 중 2개
      • Turn the entire device over, so that the underside of the device is facing upward.
      • With the underside of the device facing up, locate the 11mm screw found in each far corner of the device. Remove the single 11mm screw from each of the four corners, using the Phillips #0 screwdriver.
      댓글 쓰기
    2. Polaroid LCD-0700P Case Replacement: 2 단계, 이미지 2개 중 1개 Polaroid LCD-0700P Case Replacement: 2 단계, 이미지 2개 중 2개
      • Turn the device so that the underside faces you, and the edge where the case and device bind, faces upward. The opening of the device should be face down.
      • In this position you will see a crease line between the device and the top cover. Gently Insert your blue plastic opening tool into the crack of the crease line, between the front and back cover to separate them.
      • Be careful when separating the front and back covers, as the two are held together by a thin wire.
      • Separate the halves of the case.
      댓글 쓰기
    3. Polaroid LCD-0700P Case Replacement: 3 단계, 이미지 1개 중 1개
      • Locate the input/output board on the top left hand corner of the device. It will look like a green circuit board with wires protruding and connecting to the case cover.
      • Using your blue plastic opening tool, disconnect the multicolored wires located on the input/output board. These will be the same multicolored wires that connect the back cover to the input/output board.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
11다른 기여자 명과 함께
Mario T
회원 가입일: 01/09/12
466 평판
안내서 5개를 작성함
Cal Poly, Team 8-14, Maness Winter 2012 Cal Poly, Team 8-14, Maness Winter 2012 회원
CPSU-MANESS-W12S8G14
4 회원들
안내서 8개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 30
전체 시간: 2,379
