주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Polaroid LCD-0700P Front Panel Buttons Replacement
필요한 것
    1. Polaroid LCD-0700P Front Panel Buttons Replacement, Case: 1 단계, 이미지 2개 중 1개 Polaroid LCD-0700P Front Panel Buttons Replacement, Case: 1 단계, 이미지 2개 중 2개
      • Turn the entire device over, so that the underside of the device is facing upward.
      • With the underside of the device facing up, locate the 11mm screw found in each far corner of the device. Remove the single 11mm screw from each of the four corners, using the Phillips #0 screwdriver.
      댓글 쓰기
    2. Polaroid LCD-0700P Front Panel Buttons Replacement: 2 단계, 이미지 2개 중 1개 Polaroid LCD-0700P Front Panel Buttons Replacement: 2 단계, 이미지 2개 중 2개
      • Turn the device so that the underside faces you, and the edge where the case and device bind, faces upward. The opening of the device should be face down.
      • In this position you will see a crease line between the device and the top cover. Gently Insert your blue plastic opening tool into the crack of the crease line, between the front and back cover to separate them.
      • Be careful when separating the front and back covers, as the two are held together by a thin wire.
      • Separate the halves of the case.
      댓글 쓰기
    3. Polaroid LCD-0700P Front Panel Buttons Replacement: 3 단계, 이미지 1개 중 1개
      • Locate the input/output board on the top left hand corner of the device. It will look like a green circuit board with wires protruding and connecting to the case cover.
      • Using your blue plastic opening tool, disconnect the multicolored wires located on the input/output board. These will be the same multicolored wires that connect the back cover to the input/output board.
      댓글 쓰기
    1. Polaroid LCD-0700P Front Panel Buttons Replacement, Input/Output Board: 4 단계, 이미지 3개 중 1개 Polaroid LCD-0700P Front Panel Buttons Replacement, Input/Output Board: 4 단계, 이미지 3개 중 2개 Polaroid LCD-0700P Front Panel Buttons Replacement, Input/Output Board: 4 단계, 이미지 3개 중 3개
      • Use two blue plastic opening tools to remove the three wire connectors on the side of the input/output board.
      • Use a Philips #0 screwdriver to remove the five screws on the board.
      • One of the screws is hidden below the black tape, so gently pull the tape to the side to gain access to it. Be sure to replace the tape when reinstalling the board.
      • Lift board from case.
      댓글 쓰기
    1. Polaroid LCD-0700P Front Panel Buttons Replacement, Motherboard: 5 단계, 이미지 3개 중 1개 Polaroid LCD-0700P Front Panel Buttons Replacement, Motherboard: 5 단계, 이미지 3개 중 2개 Polaroid LCD-0700P Front Panel Buttons Replacement, Motherboard: 5 단계, 이미지 3개 중 3개
      • Remove the five different connections to this board. Two from the speakers, two from input/output board and the orange ribbon cable.
      • Remove connections from input/output board and speaker with the plastic opening tool.
      • Remove the orange ribbon cable using the plastic opening tool to release the two brown retention tabs.
      댓글 쓰기
    2. Polaroid LCD-0700P Front Panel Buttons Replacement: 6 단계, 이미지 3개 중 1개 Polaroid LCD-0700P Front Panel Buttons Replacement: 6 단계, 이미지 3개 중 2개 Polaroid LCD-0700P Front Panel Buttons Replacement: 6 단계, 이미지 3개 중 3개
      • Remove the seven 5mm screws using the Phillips #0 screwdriver.
      • Detach the wire mesh tape connection the logic board to the LCD screen with the sharp end of the spudger.
      • Remove the logic board with your hands.
      댓글 쓰기
    1. Polaroid LCD-0700P Front Panel Buttons Replacement, Front Panel Buttons: 7 단계, 이미지 1개 중 1개
      • Peel back the tape holding the button clusters down.
      댓글 쓰기
    2. Polaroid LCD-0700P Front Panel Buttons Replacement: 8 단계, 이미지 1개 중 1개
      • Slide the button clusters off of the positioning posts.
      댓글 쓰기
결론
To reassemble your device, follow these instructions in reverse order using the electrical tape to replace the ones you removed.
취소: 해당 안내서를 완성하지 않았습니다.
작성자
8다른 기여자 명과 함께
Mario T
회원 가입일: 01/09/12
466 평판
안내서 5개를 작성함
Cal Poly, Team 8-14, Maness Winter 2012 Cal Poly, Team 8-14, Maness Winter 2012 회원
CPSU-MANESS-W12S8G14
4 회원들
안내서 8개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 29
전체 시간: 1,798
