주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Polk MagniFi Soundbar Bluetooth Cable Replacement
필요한 것
    1. Polk MagniFi Soundbar Bluetooth Cable Replacement, Bluetooth Cable: 1 단계, 이미지 3개 중 1개 Polk MagniFi Soundbar Bluetooth Cable Replacement, Bluetooth Cable: 1 단계, 이미지 3개 중 2개 Polk MagniFi Soundbar Bluetooth Cable Replacement, Bluetooth Cable: 1 단계, 이미지 3개 중 3개
      • To reveal the control button, first, carefully remove the front cover of the Sound Bar.
      • Use the plastic iFixit opening tool to lift up the front surface. Insert the tool between the cover and the body to open it.
      • After the cover is fully removed, it will be able to see the interior speaker.
      • Carefully unscrew all 16 screws to release the panel.
      • There are total 16 screws that secures the panel onto the cover. Each screw is approximately 1.50 centimeter.
      댓글 쓰기
    2. Polk MagniFi Soundbar Bluetooth Cable Replacement: 2 단계, 이미지 3개 중 1개 Polk MagniFi Soundbar Bluetooth Cable Replacement: 2 단계, 이미지 3개 중 2개 Polk MagniFi Soundbar Bluetooth Cable Replacement: 2 단계, 이미지 3개 중 3개
      • To remove the cover behind the control buttons, insert the iFixit opening tool between the cover and the body
      • Push the opening tool along the edge of the cover to fully open it.
      댓글 쓰기
    3. Polk MagniFi Soundbar Bluetooth Cable Replacement: 3 단계, 이미지 1개 중 1개
      • Underneath the cover, there is a black panel screwed onto the cover with two sets of wires plugged into it.
      댓글 쓰기
    4. Polk MagniFi Soundbar Bluetooth Cable Replacement: 4 단계, 이미지 2개 중 1개 Polk MagniFi Soundbar Bluetooth Cable Replacement: 4 단계, 이미지 2개 중 2개
      • Grasp the wire firmly close to the base and pull straight out. Repeat this for the other end of the wire.
      • This wire is easily broken. Handle with care.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
[deleted]
회원 가입일: 10/22/18
695 평판
안내서 4개를 작성함
1가이드 댓글
Can you pair it with Beats headphones.?
wayne rivers - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 25
전체 시간: 2,832
