주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Polk MagniFi Soundbar Internal Power Adapter Replacement
필요한 것
    1. Polk MagniFi Soundbar Internal Power Adapter Replacement, Internal Power Adapter: 1 단계, 이미지 1개 중 1개
      • To begin, remove the 8 screws locating on the back of the soundbar. These can be removed with the ifixit screwdriver equipped with a Phillips' head in size J1.
      • The cover will lift up, but there will be wires underneath connected to the cover that need to be unscrewed. This will be shown in the next step.
      • The 8 screws on the back cover, as well as the screws removed in the following steps, are all the exact same length (approx. 1 centimeter). Keep track of all screws but do not worry if they become mixed up.
      댓글 쓰기
    2. Polk MagniFi Soundbar Internal Power Adapter Replacement: 2 단계, 이미지 2개 중 1개 Polk MagniFi Soundbar Internal Power Adapter Replacement: 2 단계, 이미지 2개 중 2개
      • Underneath the back cover, there will be two flat panels, each with two 1cm screws.
      • Remove the two screws using the Phillips #1 screwdriver. Once they are unscrewed, the panels will hang loose allowing unobstructed access to the motherboard.
      댓글 쓰기
    3. Polk MagniFi Soundbar Internal Power Adapter Replacement: 3 단계, 이미지 2개 중 1개 Polk MagniFi Soundbar Internal Power Adapter Replacement: 3 단계, 이미지 2개 중 2개
      • To detach the cables grab the internal power adapter in one hand and with the other grab the base of the wires and firmly pull them straight out from the device.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 5명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
[deleted]
회원 가입일: 10/22/18
695 평판
안내서 4개를 작성함
2가이드 댓글
where do you get the motherboard for this soundbar?
Tim - 답글 공유
Where do we get replacement part?
Leon Haddrell - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 10
지난 30일: 52
전체 시간: 2,985
