주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Polk MagniFi Soundbar Motherboard Replacement
필요한 것
    1. Polk MagniFi Soundbar Motherboard Replacement, The Motherboard: 1 단계, 이미지 1개 중 1개
      • To begin, remove the 8 screws locating on the back of the soundbar. These can be removed with the ifixit screwdriver equipped with a Phillips'head in size J1.
      • The cover will lift up, but there will be wires underneath connected to the cover that need to be unscrewed.
      • The 8 screws on the back cover, as well as the screws removed in the following steps, are all the exact same length (approx. 1 centimeter). Keep track of all screws but do not worry if they become mixed up.
      댓글 쓰기
    2. Polk MagniFi Soundbar Motherboard Replacement: 2 단계, 이미지 2개 중 1개 Polk MagniFi Soundbar Motherboard Replacement: 2 단계, 이미지 2개 중 2개
      • Remove the two screws using the Phillips #1 screwdriver. Once they are unscrewed, the panels will hang loose allowing unobstructed access to the motherboard.
      댓글 쓰기
    3. Polk MagniFi Soundbar Motherboard Replacement: 3 단계, 이미지 3개 중 1개 Polk MagniFi Soundbar Motherboard Replacement: 3 단계, 이미지 3개 중 2개 Polk MagniFi Soundbar Motherboard Replacement: 3 단계, 이미지 3개 중 3개
      • Remove the three sets of wires plugged into the motherboard (image 1). These are removed by gripping the base of the wire firmly and pulling straight up.
      • Unscrew and remove the four screws (two on either side) to release the motherboard from the rest of the soundbar (Images 2 & 3).
      댓글 쓰기
    4. Polk MagniFi Soundbar Motherboard Replacement: 4 단계, 이미지 2개 중 1개 Polk MagniFi Soundbar Motherboard Replacement: 4 단계, 이미지 2개 중 2개
      • Now that the soundbar is unscrewed, carefully lift the motherboard up and remove the wire attached to the underside of it. To do this firmly grasp the wires at the base (image 1) and pull them straight up.
      • The motherboard is now completely detached.
      • This component is fragile, and this step needs to be done carefully.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
[deleted]
회원 가입일: 10/22/18
695 평판
안내서 4개를 작성함
13가이드 댓글
Where do you buy the motherboard?
luism60613 - 답글 공유
Where do you buy the mother board?
klwalker1965 - 답글 공유
Where do you buy a replacement motherboard? ???
Todd Guenther - 답글 공유
Same question- where do you buy the replacement motherboard?
LL Poffo - 답글 공유
I need a motherboard - where do I purchase it?
Tim - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 15
지난 30일: 67
전체 시간: 9,189
