주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Polycom SoundStation Microphone Replacement
필요한 것
    1. Polycom SoundStation Microphone Replacement, Back Housing: 1 단계, 이미지 1개 중 1개
      • Flip the device over. Using a Phillips #00 screwdriver, remove the black 10mm screw on each three legs of the phone.
      • Using a Phillips #00 screwdriver, remove the two silver 7mm screws as pictured.
      댓글 쓰기
    2. Polycom SoundStation Microphone Replacement: 2 단계, 이미지 2개 중 1개 Polycom SoundStation Microphone Replacement: 2 단계, 이미지 2개 중 2개
      • Gently lift and separate the back housing from the rest of the device. Now you've got the back housing off!
      댓글 쓰기
    1. Polycom SoundStation Microphone Replacement, Microphone: 3 단계, 이미지 1개 중 1개
      • Gently remove the yellow padding that covers the red and gray microphone wire on each phone leg.
      댓글 쓰기
    2. Polycom SoundStation Microphone Replacement: 4 단계, 이미지 2개 중 1개 Polycom SoundStation Microphone Replacement: 4 단계, 이미지 2개 중 2개
      • Gently pull up on the black plastic tab connected to the motherboard to disconnect each microphone.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Cali Nowak Credit
회원 가입일: 09/02/14
431 평판
안내서 4개를 작성함
USF Sarasota-Manatee, Team 1-3, Stewart Fall 2014 USF Sarasota-Manatee, Team 1-3, Stewart Fall 2014 회원
USFSM-STEWART-F14S1G3
3 회원들
안내서 89개를 작성함
2가이드 댓글
Does anyone know where to purchase replacement microphones for Soundstation 100's? And if replacing mic's does not resolve the problem, are there any other solutions to address the issue of one's voice starting to drop out after about 10 minutes into a call? Thx
working ideas - 답글 공유
I encountered an older version. Padding pieces are black. Microphones soldered on board with black & red wires, no plastic tab to disconnect
Putting the thing back together proved to be a challenge : the little display came apart and started shifting all over. Getting that one aligned inside while closing the thing with my fat fingers… . Nasty.
Hans Deseure - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 32
전체 시간: 2,522
