주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Power Mac G4 M5183 Internal Battery Replacement
    1. Power Mac G4 M5183 Internal Battery Replacement, Opening PowerMac G4 M5183 Case: 1 단계, 이미지 2개 중 1개 Power Mac G4 M5183 Internal Battery Replacement, Opening PowerMac G4 M5183 Case: 1 단계, 이미지 2개 중 2개
      • Pull on outer latch.
      • Lower door until it is level with your work surface.
      • Before working on the computer make sure it is not plugged into a power supply, then touch a metal object. This discharges static electricity, which could damage the computer.
      댓글 쓰기
    1. Power Mac G4 M5183 Internal Battery Replacement, Internal Battery: 2 단계, 이미지 2개 중 1개 Power Mac G4 M5183 Internal Battery Replacement, Internal Battery: 2 단계, 이미지 2개 중 2개
      • Locate the battery.
      • Remove and replace battery.
      • Push the PMU button once, and only once, to reset the power supply.
      댓글 쓰기
결승점
취소: 해당 안내서를 완성하지 않았습니다.
다른 21명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Justin Petrilli
회원 가입일: 01/21/10
3,204 평판
안내서 11개를 작성함
Cal Poly, Team 13-24, Maness Winter 2010 Cal Poly, Team 13-24, Maness Winter 2010 회원
CPSU-MANESS-W10S13G24
4 회원들
안내서 55개를 작성함
4가이드 댓글
Nice simple post. You might make the battery number / size more obvious, for anxious nerds like me…
Thank you!
Lars-Peter Jorgensen - 답글 공유
Not bad, but PMU button location is not explained… the button on the front to start it?
rwwseditor - 답글 공유
Hi
Will a 3V Lithium battery work or must it be 3.6V?
Please advise.
Rgds
Duard
Duard Kleyn - 답글 공유
The PMU reset button is inside the casing, on the same circuit board as the backup battery holder. See the second photo, it's a small silver square with a circular black button inset into its top and PMU Reset in tiny white lettering beside it. The photo shows it near to the battery holder but on my model the button is further away on the far corner of the circuit board. Look around for it. Insert the new battery then press the reset ONE time only.
Robert Nicholson - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 29
지난 30일: 114
전체 시간: 27,939
