주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Power Mac G5 Bottom Right Cooling Fan Unit Replacement
    1. Power Mac G5 Bottom Right Cooling Fan Unit Replacement, Side Panel: 1 단계, 이미지 1개 중 1개
      • To avoid electrocution, shut down the computer. Do not open the computer or attempt to install any items inside it while the computer is on.
      • To avoid being burned, wait at least 10 minutes to allow the computer's internal components to cool.
      댓글 쓰기
    2. Power Mac G5 Bottom Right Cooling Fan Unit Replacement: 2 단계, 이미지 1개 중 1개
      • Remove all the cables, including the power cables before opening the unit.
      댓글 쓰기
    3. Power Mac G5 Bottom Right Cooling Fan Unit Replacement: 3 단계, 이미지 2개 중 1개 Power Mac G5 Bottom Right Cooling Fan Unit Replacement: 3 단계, 이미지 2개 중 2개
      • Lift the tab to unlock the side panel.
      • The panel should fall out. If the panel does not fall out by itself pull a little from the edges.
      댓글 쓰기
    4. Power Mac G5 Bottom Right Cooling Fan Unit Replacement: 4 단계, 이미지 3개 중 1개 Power Mac G5 Bottom Right Cooling Fan Unit Replacement: 4 단계, 이미지 3개 중 2개 Power Mac G5 Bottom Right Cooling Fan Unit Replacement: 4 단계, 이미지 3개 중 3개
      • Remove the air deflector (the clear plastic cover) by pulling on the handle.
      댓글 쓰기
    1. Power Mac G5 Bottom Right Cooling Fan Unit Replacement, Bottom Right Cooling Fan Unit: 5 단계, 이미지 2개 중 1개 Power Mac G5 Bottom Right Cooling Fan Unit Replacement, Bottom Right Cooling Fan Unit: 5 단계, 이미지 2개 중 2개
      • The cooling fan unit is located on the bottom right of the Apple G5 Desktop.
      댓글 쓰기
    2. Power Mac G5 Bottom Right Cooling Fan Unit Replacement: 6 단계, 이미지 2개 중 1개 Power Mac G5 Bottom Right Cooling Fan Unit Replacement: 6 단계, 이미지 2개 중 2개
      • Remove the G5 metal cover from the processing/cooling unit of the computer. NOTE: Apple inserted a rather fragile plastic pin that inserts through the top divider shield and clips into a tab on the hidden ledge of this CPU shield. Removing this pin, certainly voided Mac's warranty - but more appropriate for now, voids most after-market insurance plans. A replacement pin (new) is hard to get ahold of, and very few are talented and patient enough to remove this pin without damaging it. Just something to keep in mind. If you have no warranty any longer or don't care, please continue...
      • Pull the metal plate to the left and outward to remove the plate from the processing/cooling unit.
      댓글 쓰기
    3. Power Mac G5 Bottom Right Cooling Fan Unit Replacement: 7 단계, 이미지 1개 중 1개
      • Locate the bottom right fan.
      댓글 쓰기
    4. Power Mac G5 Bottom Right Cooling Fan Unit Replacement: 8 단계, 이미지 1개 중 1개
      • Unplug the fan's power cable from the upper rightmost corner of the motherboard (connection J45). If there is a video card in place, carefully pull the cable plug down between the back edge of the video card and the motherboard. Note, the photo shows the unplugged cable and the area it plugs into outlined in yellow. No video card is shown in this photo.
      댓글 쓰기
    5. Power Mac G5 Bottom Right Cooling Fan Unit Replacement: 9 단계, 이미지 2개 중 1개 Power Mac G5 Bottom Right Cooling Fan Unit Replacement: 9 단계, 이미지 2개 중 2개
      • Locate the tabs on the fan unit.
      • While pushing in on the tabs, highlighted in yellow, pull the fan back towards the cooling unit.
      댓글 쓰기
    6. Power Mac G5 Bottom Right Cooling Fan Unit Replacement: 10 단계, 이미지 2개 중 1개 Power Mac G5 Bottom Right Cooling Fan Unit Replacement: 10 단계, 이미지 2개 중 2개
      • After the latches are out, pull the fan out.
      댓글 쓰기
    7. Power Mac G5 Bottom Right Cooling Fan Unit Replacement: 11 단계, 이미지 1개 중 1개
      • After removal of the bottom right fan the space should look like this.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 33명이 해당 안내서를 완성하였습니다.
작성자
10다른 기여자 명과 함께
Adam
회원 가입일: 01/22/10
873 평판
안내서 3개를 작성함
Cal Poly, Team 5-8, Forte Winter 2010 Cal Poly, Team 5-8, Forte Winter 2010 회원
CPSU-FORTE-W10S5G8
7 회원들
안내서 41개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 30
지난 30일: 99
전체 시간: 35,479
