주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Power Mac G5 CD-ROM Drive Replacement
  1. Power Mac G5 CD-ROM Drive Replacement, Side Panel: 1 단계, 이미지 1개 중 1개
    • To avoid electrocution, shut down the computer. Do not open the computer or attempt to install any items inside it while the computer is on.
    • To avoid being burned, wait at least 10 minutes to allow the computer's internal components to cool.
    댓글 쓰기
  2. Power Mac G5 CD-ROM Drive Replacement: 2 단계, 이미지 1개 중 1개
    • Remove all the cables, including the power cables before opening the unit.
    댓글 쓰기
  3. Power Mac G5 CD-ROM Drive Replacement: 3 단계, 이미지 2개 중 1개 Power Mac G5 CD-ROM Drive Replacement: 3 단계, 이미지 2개 중 2개
    • Lift the tab to unlock the side panel.
    • The panel should fall out. If the panel does not fall out by itself pull a little from the edges.
    댓글 쓰기
  4. Power Mac G5 CD-ROM Drive Replacement: 4 단계, 이미지 3개 중 1개 Power Mac G5 CD-ROM Drive Replacement: 4 단계, 이미지 3개 중 2개 Power Mac G5 CD-ROM Drive Replacement: 4 단계, 이미지 3개 중 3개
    • Remove the air deflector (the clear plastic cover) by pulling on the handle.
    댓글 쓰기
  5. Power Mac G5 CD-ROM Drive Replacement, CD-ROM Drive: 5 단계, 이미지 1개 중 1개
    • Locate the CD-ROM Drive on the top left corner of desktop.
    댓글 쓰기
  6. Power Mac G5 CD-ROM Drive Replacement: 6 단계, 이미지 3개 중 1개 Power Mac G5 CD-ROM Drive Replacement: 6 단계, 이미지 3개 중 2개 Power Mac G5 CD-ROM Drive Replacement: 6 단계, 이미지 3개 중 3개
    • Pull and rotate latches to the left.
    댓글 쓰기
  7. Power Mac G5 CD-ROM Drive Replacement: 7 단계, 이미지 1개 중 1개
    • Wiggle and pull out the CD Drive.
    댓글 쓰기
  8. Power Mac G5 CD-ROM Drive Replacement: 8 단계, 이미지 2개 중 1개 Power Mac G5 CD-ROM Drive Replacement: 8 단계, 이미지 2개 중 2개
    • Detach the first cable from the CD-ROM drive.
    • Detach the second cable from the CD-ROM drive.
    • On some models, the IDE cable is stuck to the top of the CD-ROM with foam tape. It is easier to unplug the IDE connector from the motherboard, and de-route the IDE cable as you remove the drive.
    댓글 쓰기
  9. Power Mac G5 CD-ROM Drive Replacement: 9 단계, 이미지 1개 중 1개
    • After the CD-ROM drive is removed, the area should look like this.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 44명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Jessica Chaidez
회원 가입일: 01/13/10
8,073 평판
안내서 3개를 작성함
Cal Poly, Team 5-8, Forte Winter 2010 Cal Poly, Team 5-8, Forte Winter 2010 회원
CPSU-FORTE-W10S5G8
7 회원들
안내서 30개를 작성함
2가이드 댓글
Is it possible to use an IDE to SATA connector? I want to install my Pioneer BDR burner to potentially use the PMG5 for data disc burning only. Any thoughts?
nirv - 답글 공유
Misleading title. I know how to unplug the drive, thank you very much.
I've replaced the original drive with a better one and the %#*@ tray is stuck because it's too high.
engineer2137 - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 16
지난 30일: 70
전체 시간: 36,406
