주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Power Mac G5 Top Left Cooling Fan Unit Replacement
    1. Power Mac G5 Top Left Cooling Fan Unit Replacement, Side Panel: 1 단계, 이미지 1개 중 1개
      • To avoid electrocution, shut down the computer. Do not open the computer or attempt to install any items inside it while the computer is on.
      • To avoid being burned, wait at least 10 minutes to allow the computer's internal components to cool.
      댓글 쓰기
    2. Power Mac G5 Top Left Cooling Fan Unit Replacement: 2 단계, 이미지 1개 중 1개
      • Remove all the cables, including the power cables before opening the unit.
      댓글 쓰기
    3. Power Mac G5 Top Left Cooling Fan Unit Replacement: 3 단계, 이미지 2개 중 1개 Power Mac G5 Top Left Cooling Fan Unit Replacement: 3 단계, 이미지 2개 중 2개
      • Lift the tab to unlock the side panel.
      • The panel should fall out. If the panel does not fall out by itself pull a little from the edges.
      댓글 쓰기
    4. Power Mac G5 Top Left Cooling Fan Unit Replacement: 4 단계, 이미지 3개 중 1개 Power Mac G5 Top Left Cooling Fan Unit Replacement: 4 단계, 이미지 3개 중 2개 Power Mac G5 Top Left Cooling Fan Unit Replacement: 4 단계, 이미지 3개 중 3개
      • Remove the air deflector (the clear plastic cover) by pulling on the handle.
      댓글 쓰기
    1. Power Mac G5 Top Left Cooling Fan Unit Replacement, Top Left Cooling Fan Unit: 5 단계, 이미지 1개 중 1개
      • Locate the top left cooling fan unit.
      댓글 쓰기
    2. Power Mac G5 Top Left Cooling Fan Unit Replacement: 6 단계, 이미지 1개 중 1개
      • Pull the fan straight out from its slot. You will need to remove two cables from the motherboard.
      • It may be easier to reach the cables if you remove the PCI guide (next to the fan unit) first.
      댓글 쓰기
    3. Power Mac G5 Top Left Cooling Fan Unit Replacement: 7 단계, 이미지 1개 중 1개
      • After pulling out the fan unit, the area should look like this.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 20명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Salvador Aguilar
회원 가입일: 01/21/10
2,550 평판
안내서 3개를 작성함
Cal Poly, Team 5-8, Forte Winter 2010 Cal Poly, Team 5-8, Forte Winter 2010 회원
CPSU-FORTE-W10S5G8
7 회원들
안내서 41개를 작성함
1가이드 댓글
Actually you do need to remove the plastic air deflector, as the fan in question is behind it.
Tim downing - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 10
지난 30일: 64
전체 시간: 20,022
