주요 콘텐츠로 건너뛰기
PowerA Fusion Controller For Xbox One Motherboard Replacement
필요한 것
  1. PowerA Fusion Controller For Xbox One Motherboard Replacement, Vibration Motors: 1 단계, 이미지 3개 중 1개 PowerA Fusion Controller For Xbox One Motherboard Replacement, Vibration Motors: 1 단계, 이미지 3개 중 2개 PowerA Fusion Controller For Xbox One Motherboard Replacement, Vibration Motors: 1 단계, 이미지 3개 중 3개
    • Remove the nine 9.2mm screws with a JIS #1 screwdriver.
    • Remove the two bottom plastic grip covers.
  2. PowerA Fusion Controller For Xbox One Motherboard Replacement: 2 단계, 이미지 2개 중 1개 PowerA Fusion Controller For Xbox One Motherboard Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the two 9.2mm screws with a JIS #1 screwdriver.
    • Remove the back cover of the controller.
  3. PowerA Fusion Controller For Xbox One Motherboard Replacement: 3 단계, 이미지 2개 중 1개 PowerA Fusion Controller For Xbox One Motherboard Replacement: 3 단계, 이미지 2개 중 2개
    • Take off the glue that is on top of the soldered joints with a sprudger.
    • Desolder the soldered joints of the red and black wires that are connecting the vibration motors to the motherboard.
    • Remove the vibration motors and put them aside.
    • This guide will show how to solder and desolder connections.
  4. PowerA Fusion Controller For Xbox One Motherboard Replacement, Motherboard: 4 단계, 이미지 3개 중 1개 PowerA Fusion Controller For Xbox One Motherboard Replacement, Motherboard: 4 단계, 이미지 3개 중 2개 PowerA Fusion Controller For Xbox One Motherboard Replacement, Motherboard: 4 단계, 이미지 3개 중 3개
    • Remove the five 9.2mm screws with a JIS #1 screwdriver. Indicated by the red circles.
    • Lift the motherboard and let it hang.
  5. PowerA Fusion Controller For Xbox One Motherboard Replacement: 5 단계, 이미지 2개 중 1개 PowerA Fusion Controller For Xbox One Motherboard Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the four 9.2mm screws that are holding the D-Pad to the controller housing. Indicated by the red circles.
    • Remove the motherboard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Andrea
회원 가입일: 09/26/17
668 평판
안내서 4개를 작성함
USF Tampa, Team S14-G4, Boczar Fall 2017 USF Tampa, Team S14-G4, Boczar Fall 2017 회원
USFT-BOCZAR-F17S14G4
4 회원들
안내서 7개를 작성함
1가이드 댓글
Hi I have a powera fusion controler model CPFA115315-02 and I took the controller apart to clean and I forgot how the lb rb button springs go, I look on the internet and couldn't find anything. Any help would be great
Thanks
Nhgamer - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 18
지난 30일: 47
전체 시간: 3,574
