주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
PowerA Spectra Infinity Enhanced Vibration Motors Replacement
필요한 것
  1. PowerA Spectra Infinity Enhanced Vibration Motors Replacement, Motherboard: 1 단계, 이미지 2개 중 1개 PowerA Spectra Infinity Enhanced Vibration Motors Replacement, Motherboard: 1 단계, 이미지 2개 중 2개
    • Flip the controller so the back is facing up.
    댓글 쓰기
  2. PowerA Spectra Infinity Enhanced Vibration Motors Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the eight 10 mm screws from the back of the controller using a Phillips #0 screwdriver.
    댓글 쓰기
  3. PowerA Spectra Infinity Enhanced Vibration Motors Replacement: 3 단계, 이미지 2개 중 1개 PowerA Spectra Infinity Enhanced Vibration Motors Replacement: 3 단계, 이미지 2개 중 2개
    • Unlock the trigger locks before removing the backplate.
    • This will make taking the plate off easier.
    • Use your fingers and carefully remove the backplate.
    댓글 쓰기
  4. PowerA Spectra Infinity Enhanced Vibration Motors Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the two 10 mm screws connecting the motherboard to the faceplate using a Phillips #0 screwdriver.
    댓글 쓰기
  5. PowerA Spectra Infinity Enhanced Vibration Motors Replacement: 5 단계, 이미지 2개 중 1개 PowerA Spectra Infinity Enhanced Vibration Motors Replacement: 5 단계, 이미지 2개 중 2개
    • Use your hand to separate the motherboard from the face plate.
    댓글 쓰기
  6. PowerA Spectra Infinity Enhanced Vibration Motors Replacement, Vibration Motors: 6 단계, 이미지 2개 중 1개 PowerA Spectra Infinity Enhanced Vibration Motors Replacement, Vibration Motors: 6 단계, 이미지 2개 중 2개
    • Remove the four 7.9 mm screws using a Phillips #0 screwdriver.
    댓글 쓰기
  7. PowerA Spectra Infinity Enhanced Vibration Motors Replacement: 7 단계, 이미지 2개 중 1개 PowerA Spectra Infinity Enhanced Vibration Motors Replacement: 7 단계, 이미지 2개 중 2개
    • Use tweezers to unplug the small plug connecting the motors to the motherboard.
    • A firm grip may be necessary for this step.
    댓글 쓰기
  8. PowerA Spectra Infinity Enhanced Vibration Motors Replacement: 8 단계, 이미지 3개 중 1개 PowerA Spectra Infinity Enhanced Vibration Motors Replacement: 8 단계, 이미지 3개 중 2개 PowerA Spectra Infinity Enhanced Vibration Motors Replacement: 8 단계, 이미지 3개 중 3개
    • Remove the completely freed vibration motor from the motherboard.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Kevyn Jorge
회원 가입일: 03/22/24
1,018 평판
안내서 6개를 작성함
UMass Dartmouth, Team 6-5, Botvin Spring 2024 UMass Dartmouth, Team 6-5, Botvin Spring 2024 회원
UMASSD-BOTVIN-S24S6G5
3 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 25
전체 시간: 540
