주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
PowerBook G3 Lombard Processor Replacement
필요한 것
    1. PowerBook G3 Lombard Processor Replacement, Keyboard: 1 단계, 이미지 1개 중 1개
      • Turn the computer so that the ports are facing you.
      • If the keyboard is locked, open the port cover and turn the keyboard locking screw until the keyboard is unlocked.
      댓글 쓰기
    2. PowerBook G3 Lombard Processor Replacement: 2 단계, 이미지 1개 중 1개
      • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
      • Make sure you have removed the laptop battery and CD/DVD module from the expansion bays before proceeding.
      댓글 쓰기
    3. PowerBook G3 Lombard Processor Replacement: 3 단계, 이미지 1개 중 1개
      • Lift the keyboard out by pulling it up and away from you. Rest the keyboard, face down, on top of the trackpad.
      • In order to replace the keyboard, you must first remove the modem.
      댓글 쓰기
    1. PowerBook G3 Lombard Processor Replacement, Heat Shield: 4 단계, 이미지 1개 중 1개
      • Remove the three silver Phillips screws that attach the heat shield to the internal metal framework.
      댓글 쓰기
    2. PowerBook G3 Lombard Processor Replacement: 5 단계, 이미지 1개 중 1개
      • Lift the heat shield up and pull it toward you.
      댓글 쓰기
    3. PowerBook G3 Lombard Processor Replacement: 6 단계, 이미지 1개 중 1개
      • Your laptop should look approximately like this.
      댓글 쓰기
    1. PowerBook G3 Lombard Processor Replacement, PRAM Battery: 7 단계, 이미지 1개 중 1개
      • Pull the battery cable directly up from the logic board.
      댓글 쓰기
    2. PowerBook G3 Lombard Processor Replacement: 8 단계, 이미지 1개 중 1개
      • Remove the battery from its holder by pulling up and to the left.
      댓글 쓰기
    1. PowerBook G3 Lombard Processor Replacement, Modem: 9 단계, 이미지 1개 중 1개
      • Remove the two silver Phillips screws from the modem.
      댓글 쓰기
    2. PowerBook G3 Lombard Processor Replacement: 10 단계, 이미지 1개 중 1개
      • Use a spudger, the tips of your fingers, or a flat non-metal tool to get under the modem's edge and pry it up from its socket as shown in the picture.
      댓글 쓰기
    3. PowerBook G3 Lombard Processor Replacement: 11 단계, 이미지 1개 중 1개
      • Disconnect the cable from the right side of the modem.
      댓글 쓰기
    4. PowerBook G3 Lombard Processor Replacement: 12 단계, 이미지 1개 중 1개
      댓글 쓰기
    1. PowerBook G3 Lombard Processor Replacement, Processor: 13 단계, 이미지 1개 중 1개
      • Use a spudger, the tips of your fingers, or a flat non-metal tool to pry up the processor's right side.
      댓글 쓰기
    2. PowerBook G3 Lombard Processor Replacement: 14 단계, 이미지 1개 중 1개
      • Disconnect the keyboard cable from the logic board by pulling directly up on the clear plastic loop.
      • This step is out of sequence with the keyboard because in order to remove the keyboard you must first remove the modem.
      댓글 쓰기
    3. PowerBook G3 Lombard Processor Replacement: 15 단계, 이미지 1개 중 1개
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 5명이 해당 안내서를 완성하였습니다.
첨부 문서
작성자
1다른 기여자 명과 함께
iRobot
회원 가입일: 09/24/09
1 평판
안내서 636개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 41
전체 시간: 6,406
