주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
PowerBook G3 Wallstreet Processor Replacement
필요한 것
  1. PowerBook G3 Wallstreet Processor Replacement, Keyboard: 1 단계, 이미지 1개 중 1개
    • Remove both expansion bay modules using the levers on the front of the computer.
    • Insert your index fingers inside the expansion bays and search for the two ribbed tabs on the underside of the upper case. The tabs are located near the bottom corners of the keyboard.
    • Pull the tabs toward yourself and the keyboard will pop up.
    댓글 쓰기
  2. PowerBook G3 Wallstreet Processor Replacement: 2 단계, 이미지 1개 중 1개
    • Pull the keyboard forward to disengage the tabs holding it in back and rotate it toward you.
    • Rest the keyboard on the trackpad.
    댓글 쓰기
    • This is a diagram of the ribbon clamp connectors you will disconnect in the next step.
    • 1) With your fingernails, grasp the locking bar on either side and pull up a small amount (about 1/16" or 2 mm).
    • 2) After disengaging the locking bar, slide the cable out of the connector.
    댓글 쓰기
  3. PowerBook G3 Wallstreet Processor Replacement: 4 단계, 이미지 1개 중 1개
    • Disconnect the two keyboard connectors by disengaging the clamps and pulling the ribbons directly upward.
    댓글 쓰기
  4. PowerBook G3 Wallstreet Processor Replacement: 5 단계, 이미지 1개 중 1개
    • Slide a spudger downward between each plastic strain relief cable and the wall of the case in order to bow out the cable beyond the small tab holding it in place.
    • Once the strain relief cables are free, lift the keyboard off.
    댓글 쓰기
  5. PowerBook G3 Wallstreet Processor Replacement: 6 단계, 이미지 1개 중 1개
    • Your laptop should look approximately like this.
    댓글 쓰기
  6. PowerBook G3 Wallstreet Processor Replacement, Heat Shield: 7 단계, 이미지 1개 중 1개
    • Remove the two Phillips screws from the heat shield.
    • One screw is shorter than the other. When putting the Wallstreet back together, this screw goes in the middle of the heat shield.
    댓글 쓰기
  7. PowerBook G3 Wallstreet Processor Replacement: 8 단계, 이미지 1개 중 1개
    • Grasp the metal handle on the heat shield and pull up and toward yourself.
    댓글 쓰기
  8. PowerBook G3 Wallstreet Processor Replacement, Hard Drive: 9 단계, 이미지 1개 중 1개
    • Unscrew, but do not remove, the single Phillips screw from the hard drive bracket.
    댓글 쓰기
  9. PowerBook G3 Wallstreet Processor Replacement: 10 단계, 이미지 1개 중 1개
    • Grasp the hard drive bracket on the left side and pull up and to the left.
    댓글 쓰기
  10. PowerBook G3 Wallstreet Processor Replacement: 11 단계, 이미지 1개 중 1개
    댓글 쓰기
  11. PowerBook G3 Wallstreet Processor Replacement, Processor: 12 단계, 이미지 1개 중 1개
    • Use a spudger, the tips of your fingers, or a flat non-metal tool to pry up the processor's right side.
    • Remove the processor by sliding it up and to the right.
    • The processor and RAM can be removed as a unit. It is not necessary to remove the RAM from the processor.
    • There are two tabs on the left side of the processor that fit into slots on the metal framework. Make sure these tabs are in the slots.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 5명이 해당 안내서를 완성하였습니다.
첨부 문서
작성자
4다른 기여자 명과 함께
iRobot
회원 가입일: 09/24/09
1 평판
안내서 636개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 18
지난 30일: 63
전체 시간: 9,198
