주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
PowerBook G4 Titanium DVI Inverter Replacement
필요한 것
  1. PowerBook G4 Titanium DVI Inverter Replacement, Battery: 1 단계, 이미지 2개 중 1개 PowerBook G4 Titanium DVI Inverter Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Locate the battery release tab on the underside of the G4.
    • Slide the battery release tab to the left and lift the battery out of the computer.
    댓글 쓰기
  2. PowerBook G4 Titanium DVI Inverter Replacement, Lower Case: 2 단계, 이미지 2개 중 1개 PowerBook G4 Titanium DVI Inverter Replacement, Lower Case: 2 단계, 이미지 2개 중 2개
    • Remove the seven T8 Torx screws from the lower case.
    • Using your thumbs, slide the lower case toward the front of the computer.
    • The lower case may stick in the front on a tab just above the center of the optical drive. Be careful as you work the case off, or you may break the thin strip of plastic just above the drive.
    • Lift the lower case off.
    댓글 쓰기
  3. PowerBook G4 Titanium DVI Inverter Replacement, Hard Drive: 3 단계, 이미지 1개 중 1개
    • Disconnect the hard drive ribbon from the logic board using a spudger or the tip of your finger.
    댓글 쓰기
  4. PowerBook G4 Titanium DVI Inverter Replacement: 4 단계, 이미지 1개 중 1개
    • To free the hard drive, remove the two T8 Torx screws from the right wall of the battery housing.
    댓글 쓰기
  5. PowerBook G4 Titanium DVI Inverter Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the hard drive by lifting the left edge up and out of the computer.
    • There are four rubber bumpers that fit over the hard drive screws. Ensure that these bumpers come out when you remove the hard drive.
    댓글 쓰기
  6. PowerBook G4 Titanium DVI Inverter Replacement: 6 단계, 이미지 1개 중 1개
    • Your laptop should look approximately like this.
    댓글 쓰기
  7. PowerBook G4 Titanium DVI Inverter Replacement, Optical Drive Removal: 7 단계, 이미지 1개 중 1개
    • Disconnect and remove the indicated orange ribbon cable.
    댓글 쓰기
  8. PowerBook G4 Titanium DVI Inverter Replacement: 8 단계, 이미지 1개 중 1개
    • Disconnect the pink and white inverter cable from the inverter board.
    • The display inverter has orange plastic shielding around it that looks similar to the tape used elsewhere within the computer. Do not remove the shielding from the inverter.
    댓글 쓰기
  9. PowerBook G4 Titanium DVI Inverter Replacement: 9 단계, 이미지 1개 중 1개
    • Remove the two silver T8 Torx screws from the black plastic bar.
    • Lift the black plastic bar out.
    • Reassembly will be significantly easier if you reseat the hard drive before returning the black bar to its place.
    댓글 쓰기
  10. PowerBook G4 Titanium DVI Inverter Replacement: 10 단계, 이미지 1개 중 1개
    • Disconnect the two orange connectors from the logic board, removing tape as necessary.
    댓글 쓰기
  11. PowerBook G4 Titanium DVI Inverter Replacement: 11 단계, 이미지 1개 중 1개
    • Lift the drive up on the right side so that you can access and disconnect the modem cable and inverter cable.
    댓글 쓰기
  12. PowerBook G4 Titanium DVI Inverter Replacement: 12 단계, 이미지 1개 중 1개
    • Remove the drive by lifting the right edge up and out of the computer.
    댓글 쓰기
  13. PowerBook G4 Titanium DVI Inverter Replacement, Modem: 13 단계, 이미지 1개 중 1개
    • Remove the two T6 Torx screws from the modem.
    • Lift the modem off the optical drive, carefully guiding the orange ribbon cable through the space in the drive mount.
    댓글 쓰기
  14. PowerBook G4 Titanium DVI Inverter Replacement, Inverter: 14 단계, 이미지 1개 중 1개
    • Remove the two T6 Torx screws from the inverter board.
    • Lift the inverter board off the optical drive.
    댓글 쓰기
  15. PowerBook G4 Titanium DVI Inverter Replacement: 15 단계, 이미지 1개 중 1개
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 12명이 해당 안내서를 완성하였습니다.
첨부 문서
작성자
4다른 기여자 명과 함께
iRobot
회원 가입일: 09/24/09
1 평판
안내서 636개를 작성함
2가이드 댓글
I didn't need to remove the modem on my Antimony model.
Fred Hood - 답글 공유
Absolutely no reason to remove the HDD, modem, or optical drive to do this on the 1GHz model. Remove the back cover and the two screws that hold the inverter in place, and thats all you need to do.
insaneiaq - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 61
전체 시간: 15,346
