주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
PowerBook G4 Titanium DVI Latch Replacement
필요한 것
    1. PowerBook G4 Titanium DVI Latch Replacement, Battery: 1 단계, 이미지 2개 중 1개 PowerBook G4 Titanium DVI Latch Replacement, Battery: 1 단계, 이미지 2개 중 2개
      • Locate the battery release tab on the underside of the G4.
      • Slide the battery release tab to the left and lift the battery out of the computer.
      댓글 쓰기
    1. PowerBook G4 Titanium DVI Latch Replacement, Lower Case: 2 단계, 이미지 2개 중 1개 PowerBook G4 Titanium DVI Latch Replacement, Lower Case: 2 단계, 이미지 2개 중 2개
      • Remove the seven T8 Torx screws from the lower case.
      • Using your thumbs, slide the lower case toward the front of the computer.
      • The lower case may stick in the front on a tab just above the center of the optical drive. Be careful as you work the case off, or you may break the thin strip of plastic just above the drive.
      • Lift the lower case off.
      댓글 쓰기
    1. PowerBook G4 Titanium DVI Latch Replacement, Hard Drive: 3 단계, 이미지 1개 중 1개
      • Disconnect the hard drive ribbon from the logic board using a spudger or the tip of your finger.
      댓글 쓰기
    2. PowerBook G4 Titanium DVI Latch Replacement: 4 단계, 이미지 1개 중 1개
      • To free the hard drive, remove the two T8 Torx screws from the right wall of the battery housing.
      댓글 쓰기
    3. PowerBook G4 Titanium DVI Latch Replacement: 5 단계, 이미지 1개 중 1개
      • Remove the hard drive by lifting the left edge up and out of the computer.
      • There are four rubber bumpers that fit over the hard drive screws. Ensure that these bumpers come out when you remove the hard drive.
      댓글 쓰기
    4. PowerBook G4 Titanium DVI Latch Replacement: 6 단계, 이미지 1개 중 1개
      • Your laptop should look approximately like this.
      댓글 쓰기
    1. PowerBook G4 Titanium DVI Latch Replacement, Latch: 7 단계, 이미지 1개 중 1개
      • Use your thumbnails to push in and then lift the two fingers of the latch clip over the restraining bar.
      댓글 쓰기
    2. PowerBook G4 Titanium DVI Latch Replacement: 8 단계, 이미지 1개 중 1개
      • Now use your index fingers' nails to pull at the "elbows" of the clip, rotating it upward approximately 90 degrees, or until the latch pops out
      댓글 쓰기
    3. PowerBook G4 Titanium DVI Latch Replacement: 9 단계, 이미지 1개 중 1개
      • Insert the new latch by rotating the clip up and pushing the latch into place. Then rotate the clip back down, pushing in at the area where the clip bends around the latch. Make sure to insert the clip fingers back into their slots.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 5명이 해당 안내서를 완성하였습니다.
첨부 문서
작성자
1다른 기여자 명과 함께
iRobot
회원 가입일: 09/24/09
1 평판
안내서 635개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 10
지난 30일: 42
전체 시간: 8,672
