주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
PowerShot G7 X Mark II LCD Screen Replacement
필요한 것
    1. PowerShot G7 X Mark II LCD Screen Replacement, LCD Screen: 1 단계, 이미지 1개 중 1개
      • Use a Philips #000 screwdriver to remove the three 2mm screws on the bottom of the LCD screen.
      댓글 쓰기
    2. PowerShot G7 X Mark II LCD Screen Replacement: 2 단계, 이미지 1개 중 1개
      • Tilt the LCD screen all the way up and use a Phillips #000 screwdriver to remove the three 4mm screws from the back of the LCD screen.
      댓글 쓰기
    3. PowerShot G7 X Mark II LCD Screen Replacement, Remove back panel from LCD screen: 3 단계, 이미지 1개 중 1개
      • Use a spudger tool to release the ribbon cable from the ZIF connector.
      • The cable is thin and delicate. Detach with care.
      • Gently pry off the screen until the double-sided tape behind the back panel gives in.
      댓글 쓰기
    4. PowerShot G7 X Mark II LCD Screen Replacement: 4 단계, 이미지 1개 중 1개
      • The screen is detached and can now be replaced.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 5명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Brandon
회원 가입일: 02/15/17
644 평판
안내서 4개를 작성함
USF Tampa, Team 12-3, Eyestone Spring 2017 USF Tampa, Team 12-3, Eyestone Spring 2017 회원
USFT-EYESTONE-S17S12G3
3 회원들
안내서 4개를 작성함
5가이드 댓글
Are there any problems with the replacement screen? It’s a touch screen, just making sure the functionality of the screen is still intact.
Andrew Baez - 답글 공유
These directions do not give enough information. The screed is glued into the frame. The replacement parts do not come with the circuit board.
alan saltus - 답글 공유
Did you successfully replace the screen? I took off the screws, and got to the detaching the wire stage but then discovered as you said “the glue”. Any further insight would be appreciated!
rachelkernali - 답글 공유
My G7X lost one of the 2 screws holding the screen: do you know where I can find them?
paolofarinella - 답글 공유
on ebay or amazon. you can order it
nicole - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 35
지난 30일: 169
전체 시간: 12,363
