주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
PowerShot G7 X Mark II Top Cover Button Panel Replacement
필요한 것
    1. PowerShot G7 X Mark II Top Cover Button Panel Replacement, Top Cover Button Panel: 1 단계, 이미지 2개 중 1개 PowerShot G7 X Mark II Top Cover Button Panel Replacement, Top Cover Button Panel: 1 단계, 이미지 2개 중 2개
      • Use a Phillips #000 screwdriver to remove four 4mm screws from the NFC panel cover on the bottom of the camera.
      댓글 쓰기
    2. PowerShot G7 X Mark II Top Cover Button Panel Replacement: 2 단계, 이미지 2개 중 1개 PowerShot G7 X Mark II Top Cover Button Panel Replacement: 2 단계, 이미지 2개 중 2개
      • Use a Phillips #000 screwdriver to remove five screws from under the LCD screen:
      • Three 2.4 mm screws
      • Two 3 mm screws
      댓글 쓰기
    3. PowerShot G7 X Mark II Top Cover Button Panel Replacement: 3 단계, 이미지 1개 중 1개
      • Use a Phillips #000 screwdriver to remove two 3mm screws on the left of the camera.
      댓글 쓰기
    4. PowerShot G7 X Mark II Top Cover Button Panel Replacement: 4 단계, 이미지 2개 중 1개 PowerShot G7 X Mark II Top Cover Button Panel Replacement: 4 단계, 이미지 2개 중 2개
      • Use a Phillips #000 screwdriver to remove one 3mm and one 4mm screw on the surface of the right face of the camera, and one under the USB/HDMI cover.
      댓글 쓰기
    5. PowerShot G7 X Mark II Top Cover Button Panel Replacement: 5 단계, 이미지 2개 중 1개 PowerShot G7 X Mark II Top Cover Button Panel Replacement: 5 단계, 이미지 2개 중 2개
      • Carefully remove the back cover off of the camera by hand. Press the brown actuator in the FFC socket to release the FPC (Flexible Printed Circuit - brown cable attached to the back cover) and pull the FPC out of the socket.
      • If the FPC doesn't come out easily, you haven't yet released it. Do not force it. Do not use a spudger because it will break the socket. A broken socket cannot be fixed and has to be replaced by a skilled technician.
      댓글 쓰기
    6. PowerShot G7 X Mark II Top Cover Button Panel Replacement: 6 단계, 이미지 2개 중 1개 PowerShot G7 X Mark II Top Cover Button Panel Replacement: 6 단계, 이미지 2개 중 2개
      • Use a Phillips #000 screwdriver to remove two 3mm screws on the pop-up flash.
      댓글 쓰기
    7. PowerShot G7 X Mark II Top Cover Button Panel Replacement: 7 단계, 이미지 2개 중 1개 PowerShot G7 X Mark II Top Cover Button Panel Replacement: 7 단계, 이미지 2개 중 2개
      • Use a Phillips #000 screwdriver to remove two 2mm screws attaching the button panel to the camera body.
      • Use a Phillips #000 screwdriver to remove a 3mm screw from beneath the mode dial.
      댓글 쓰기
    8. PowerShot G7 X Mark II Top Cover Button Panel Replacement: 8 단계, 이미지 3개 중 1개 PowerShot G7 X Mark II Top Cover Button Panel Replacement: 8 단계, 이미지 3개 중 2개 PowerShot G7 X Mark II Top Cover Button Panel Replacement: 8 단계, 이미지 3개 중 3개
      • Open the battery compartment and remove the battery by flipping the small latch holding it in.
      • Use a Phillips #000 screwdriver to remove one 6mm screw in the bottom of the battery compartment.
      댓글 쓰기
    9. PowerShot G7 X Mark II Top Cover Button Panel Replacement: 9 단계, 이미지 2개 중 1개 PowerShot G7 X Mark II Top Cover Button Panel Replacement: 9 단계, 이미지 2개 중 2개
      • Pry the top cover button assembly off of the camera body by detaching clips around the base of it.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Brandon
회원 가입일: 02/15/17
644 평판
안내서 4개를 작성함
USF Tampa, Team 12-3, Eyestone Spring 2017 USF Tampa, Team 12-3, Eyestone Spring 2017 회원
USFT-EYESTONE-S17S12G3
3 회원들
안내서 4개를 작성함
1가이드 댓글
We followed this guide but now my camera will not turn on. The little green light by the play button will light up but thats it. Any idea what went wrong?
Alexa Smith - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 16
지난 30일: 84
전체 시간: 4,091
