주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Pre-Lit Christmas Tree Incandescent Light Fuse Replacement
필요한 것
  1. Pre-Lit Christmas Tree Incandescent Light Fuse Replacement, Fuse: 1 단계, 이미지 2개 중 1개 Pre-Lit Christmas Tree Incandescent Light Fuse Replacement, Fuse: 1 단계, 이미지 2개 중 2개
    • Plug in the tree.
    • Use a Christmas light function tester to check the fuse on a light that is not bright.
    • The red light on the function tester will not light up if the fuse is dead.
    댓글 쓰기
  2. Pre-Lit Christmas Tree Incandescent Light Fuse Replacement: 2 단계, 이미지 1개 중 1개
    • Unplug the tree from the outlet.
    댓글 쓰기
  3. Pre-Lit Christmas Tree Incandescent Light Fuse Replacement: 3 단계, 이미지 3개 중 1개 Pre-Lit Christmas Tree Incandescent Light Fuse Replacement: 3 단계, 이미지 3개 중 2개 Pre-Lit Christmas Tree Incandescent Light Fuse Replacement: 3 단계, 이미지 3개 중 3개
    • Open the fuse cover, then use a small flathead screwdriver or spudger to carefully remove the fuse.
    댓글 쓰기
  4. Pre-Lit Christmas Tree Incandescent Light Fuse Replacement: 4 단계, 이미지 1개 중 1개
    • Using a continuity tester and the fuse, place both tips of the continuity tester on either side of the fuse.
    • The top light should light up red if the fuse is in working condition. If no light appears, repeat this step with a new fuse.
    댓글 쓰기
  5. Pre-Lit Christmas Tree Incandescent Light Fuse Replacement: 5 단계, 이미지 3개 중 1개 Pre-Lit Christmas Tree Incandescent Light Fuse Replacement: 5 단계, 이미지 3개 중 2개 Pre-Lit Christmas Tree Incandescent Light Fuse Replacement: 5 단계, 이미지 3개 중 3개
    • Carefully insert the working fuse back into the tree plug, and put the cover on.
    댓글 쓰기
  6. Pre-Lit Christmas Tree Incandescent Light Fuse Replacement: 6 단계, 이미지 1개 중 1개
    • Plug the tree back into the outlet.
    댓글 쓰기
  7. Pre-Lit Christmas Tree Incandescent Light Fuse Replacement: 7 단계, 이미지 1개 중 1개
    • Using the Christmas light function tester, go back to the same spot you initially checked. If the red light appears, you have successfully replaced the fuse!
    • The red light will appear whether the bulb itself is working or not.
    댓글 쓰기
결론
Thank you for using this guide!
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Elizabeth Harvey
회원 가입일: 10/05/20
179 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 9
지난 30일: 54
전체 시간: 4,581
