주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Preliminary Main Board Removal
필요한 것
    1. Preliminary Main Board Removal, Exterior Housing: 1 단계, 이미지 3개 중 1개 Preliminary Main Board Removal, Exterior Housing: 1 단계, 이미지 3개 중 2개 Preliminary Main Board Removal, Exterior Housing: 1 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      iOpener
      $24.95
      • Pry the exterior housing off the iHome iP37. You may need extra leverage to do this.
      • Note: This step is the most difficult due to the way it is attached. The glue holding the exterior housing to the internals does not break easily. You may want to use iFixit's iOpener to soften the glue.
      • Note: The process is the same for both the upper half and the lower half. To identify the halves, look for these details: the upper half has a metal grid, and the lower half has buttons. If you are replacing any other components, pry off the lower half.
      댓글 쓰기
    1. Preliminary Main Board Removal, Lower Half Casing: 2 단계, 이미지 3개 중 1개 Preliminary Main Board Removal, Lower Half Casing: 2 단계, 이미지 3개 중 2개 Preliminary Main Board Removal, Lower Half Casing: 2 단계, 이미지 3개 중 3개
      • Remove these four 9 mm screws from the plastic casing; you will need a Phillips #2 driver to do this.
      • Remove the flanged 9 mm screw from the counterweight; you will need a Phillips #2 driver to do this.
      • Lift and remove the counterweight.
      댓글 쓰기
    2. Preliminary Main Board Removal: 3 단계, 이미지 3개 중 1개 Preliminary Main Board Removal: 3 단계, 이미지 3개 중 2개 Preliminary Main Board Removal: 3 단계, 이미지 3개 중 3개
      • Lift and remove the plastic casing.
      • Note: It is best to lift the casing starting from the side without the protruding 3.5mm audio port and power port.
      • Reminder: During this process, a rubber cover will likely be dislodged. Make sure to re-seat this cover on the small pegs before putting the plastic casing back on.
      댓글 쓰기
    1. Preliminary Main Board Removal, Preliminary Main Board: 4 단계, 이미지 2개 중 1개 Preliminary Main Board Removal, Preliminary Main Board: 4 단계, 이미지 2개 중 2개
      • Remove the two 9 mm screws that hold the main printed circuit board onto the rest of the iP37; you will need a Phillips #2 driver to do this.
      댓글 쓰기
    2. Preliminary Main Board Removal: 5 단계, 이미지 1개 중 1개
      • Peel away the black tape covering the red wires that connect to the PCB.
      댓글 쓰기
    3. Preliminary Main Board Removal: 6 단계, 이미지 1개 중 1개
      • There is ribbon wiring under this PCB. Be careful not to damage it while removing the PCB.
      • Slowly lift the PCB away from the rest of the device
      • Remove the ribbon by first removing the brown insert piece from the connector on the button board
      • Pull the ribbon out of the connector on the button board by the blue tab.
      댓글 쓰기
    4. Preliminary Main Board Removal: 7 단계, 이미지 1개 중 1개
      • Carefully disconnect the white 11-pin connector from the main board.
      • Pull firmly on the connector and use a screwdriver to pry it slightly if necessary.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Jerrell
회원 가입일: 04/23/14
730 평판
안내서 7개를 작성함
Cal Poly, Team 11-50, Amido Spring 2014 Cal Poly, Team 11-50, Amido Spring 2014 회원
CPSU-AMIDO-S14S11G50
4 회원들
안내서 40개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 23
전체 시간: 1,024
