주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Prerequisite Lower Half Casing Disassembly
필요한 것
    1. Prerequisite Lower Half Casing Disassembly, Exterior Housing: 1 단계, 이미지 3개 중 1개 Prerequisite Lower Half Casing Disassembly, Exterior Housing: 1 단계, 이미지 3개 중 2개 Prerequisite Lower Half Casing Disassembly, Exterior Housing: 1 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      iOpener
      $24.95
      • Pry the exterior housing off the iHome iP37. You may need extra leverage to do this.
      • Note: This step is the most difficult due to the way it is attached. The glue holding the exterior housing to the internals does not break easily. You may want to use iFixit's iOpener to soften the glue.
      • Note: The process is the same for both the upper half and the lower half. To identify the halves, look for these details: the upper half has a metal grid, and the lower half has buttons. If you are replacing any other components, pry off the lower half.
      댓글 쓰기
    1. Prerequisite Lower Half Casing Disassembly, Lower Half Casing: 2 단계, 이미지 3개 중 1개 Prerequisite Lower Half Casing Disassembly, Lower Half Casing: 2 단계, 이미지 3개 중 2개 Prerequisite Lower Half Casing Disassembly, Lower Half Casing: 2 단계, 이미지 3개 중 3개
      • Remove these four 9 mm screws from the plastic casing; you will need a Phillips #2 driver to do this.
      • Remove the flanged 9 mm screw from the counterweight; you will need a Phillips #2 driver to do this.
      • Lift and remove the counterweight.
      댓글 쓰기
    2. Prerequisite Lower Half Casing Disassembly: 3 단계, 이미지 3개 중 1개 Prerequisite Lower Half Casing Disassembly: 3 단계, 이미지 3개 중 2개 Prerequisite Lower Half Casing Disassembly: 3 단계, 이미지 3개 중 3개
      • Lift and remove the plastic casing.
      • Note: It is best to lift the casing starting from the side without the protruding 3.5mm audio port and power port.
      • Reminder: During this process, a rubber cover will likely be dislodged. Make sure to re-seat this cover on the small pegs before putting the plastic casing back on.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
Jerrell
회원 가입일: 04/23/14
730 평판
안내서 7개를 작성함
Cal Poly, Team 11-50, Amido Spring 2014 Cal Poly, Team 11-50, Amido Spring 2014 회원
CPSU-AMIDO-S14S11G50
4 회원들
안내서 26개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 36
전체 시간: 613
