주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Printer setup in Linux (Mint, etc)
필요한 것
    • Connect the printer to your computer with a USB cable.
    • The USB-B plug goes in the back of the printer.
    • Make sure the computer and printer are both switched on.
    댓글 쓰기
    • Go to Start menu > System > Printers if it hasn't opened automatically.
    • Now click Add printer and look for the make and model.
    • If you see XP-220 listed in the Epson category, your computer probably has the correct Epson printer driver and you can skip to Step 4.
    • If you don't see XP-220 as an option, pause here and open the software installer (under Start menu > System by default).
    댓글 쓰기
    • Linux Mint's stock software "store" has the Epson driver easily available. Search "epson" and the driver should come up as one of, if not the first option.
    • Click Install. Type in the superuser password it asks for (depending on how your account is set up, this may be your own password or an admin's password).
    댓글 쓰기
    • When the printer driver is installed, go back to the printer setup.
    • Now when you add your printer, XP-220 will appear in the long list of Epson models. Select that and the computer will now connect to the printer easily.
    댓글 쓰기
    • You can print a test page to make sure the printer is working.
    댓글 쓰기
결론
This is written for Linux Mint, but also applies to other Linux distributions with similar menu options.
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Sparky
회원 가입일: 03/15/26
1,535 평판
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 17
전체 시간: 17
