주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
ProScan PLT7223G Screen Replacement
필요한 것
  1. ProScan PLT7223G Screen Replacement, Screen: 1 단계, 이미지 1개 중 1개
    • Remove both 4 mm screws on the top of the tablet with a PH00 screw driver.
  2. ProScan PLT7223G Screen Replacement: 2 단계, 이미지 1개 중 1개
    • Use the blue plastic opening tool to pry open the tablet.
    • You will hear popping sounds. That's okay.
    • Be careful when using the blue plastic opening tool on the side of the device near the speakers, as there is a wire here that connects the speakers to the motherboard.
  3. ProScan PLT7223G Screen Replacement: 3 단계, 이미지 1개 중 1개
    • Remove three 4 mm screws from the motherboard.
  4. ProScan PLT7223G Screen Replacement: 4 단계, 이미지 1개 중 1개
    • Insert a spudger under the black tape that connects the silver wire to the interior of the front panel
    • Pull back the black tape with the spudger until it can be lifted up with your fingers.
    • Use your fingers to grab and lift the remainder of the black tape from device panel.
  5. ProScan PLT7223G Screen Replacement: 5 단계, 이미지 1개 중 1개
    • Use a plastic opening tool to push back the ZIF connector to release the ribbon wire on the motherboard.
  6. ProScan PLT7223G Screen Replacement: 6 단계, 이미지 1개 중 1개
    • Insert an opening tool underneath the silver base of the internal device element.
    • Use the opening tool to pry the element out of the case that holds the screen.
    • You will need to release a number of clips in order to remove the screen.
    • Be careful not to damage the motherboard or battery as you go.
결론
다른 6명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Nathaniel Girard
회원 가입일: 01/12/16
290 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 6
지난 30일: 19
전체 시간: 2,020
