주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Professional Series PS77401 Lever Spring Replacement
필요한 것
    1. Professional Series PS77401 Lever Spring Replacement, Shell: 1 단계, 이미지 1개 중 1개
      • Make sure that the toaster is unplugged before attempting any sort of disassembly!
      댓글 쓰기
    2. Professional Series PS77401 Lever Spring Replacement: 2 단계, 이미지 2개 중 1개 Professional Series PS77401 Lever Spring Replacement: 2 단계, 이미지 2개 중 2개
      • Grip the black plastic lever nub firmly and carefully remove it from the metal lever. Use one hand to hold the toaster in place while you pull the lever nub with the other.
      • If this is the first time detaching this piece, it will take some effort to remove. Be careful as pulling too hard can cause damage to the inner lever mechanism.
      댓글 쓰기
    3. Professional Series PS77401 Lever Spring Replacement: 3 단계, 이미지 3개 중 1개 Professional Series PS77401 Lever Spring Replacement: 3 단계, 이미지 3개 중 2개 Professional Series PS77401 Lever Spring Replacement: 3 단계, 이미지 3개 중 3개
      • Flipping the toaster upside down, use a T7 Torx Screwdriver to remove the four 10mm screws that keep the outer shell attached.
      • Flip the toaster back over and slide off the shell making sure to slip the toaster lever (now without the black plastic nub) through the lever opening in the shell.
      • The outer shell should now only be connected by its internal wiring.
      댓글 쓰기
    4. Professional Series PS77401 Lever Spring Replacement: 4 단계, 이미지 2개 중 1개 Professional Series PS77401 Lever Spring Replacement: 4 단계, 이미지 2개 중 2개
      • Locate and remove the two 8mm screws that attach the circuit board (located inside of the shell) from the shell itself using the Phillips #2 screwdriver.
      • The shell should now be completely separated from the rest of the toaster.
      댓글 쓰기
    1. Professional Series PS77401 Lever Spring Replacement, Lever Spring: 5 단계, 이미지 1개 중 1개
      • Locate your damaged spring that holds the toaster lever in place.
      • The spring in the picture is not damaged.
      댓글 쓰기
    2. Professional Series PS77401 Lever Spring Replacement: 6 단계, 이미지 2개 중 1개 Professional Series PS77401 Lever Spring Replacement: 6 단계, 이미지 2개 중 2개
      • Disconnect the bottom part of the damaged spring from the lever first.
      • Then disconnect the top part of the damaged spring from the chassis.
      댓글 쓰기
    3. Professional Series PS77401 Lever Spring Replacement: 7 단계, 이미지 2개 중 1개 Professional Series PS77401 Lever Spring Replacement: 7 단계, 이미지 2개 중 2개
      • Attach the new spring in the same spots that the damaged spring was removed from.
      • Check to make sure that the new spring allows the lever to move down with slight resistance and that it pops back up after being released.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
David Acosta
회원 가입일: 01/24/14
125 평판
안내서 1개를 작성함
Cal Poly, Team 10-36, Maness Winter 2014 Cal Poly, Team 10-36, Maness Winter 2014 회원
CPSU-MANESS-W14S10G36
4 회원들
안내서 15개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 14
지난 30일: 46
전체 시간: 2,134
