주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
ProfiMixx 44 Disassembly
    1. ProfiMixx 44 Disassembly, Removing the scrapers: 1 단계, 이미지 3개 중 1개 ProfiMixx 44 Disassembly, Removing the scrapers: 1 단계, 이미지 3개 중 2개 ProfiMixx 44 Disassembly, Removing the scrapers: 1 단계, 이미지 3개 중 3개
      • Removing the five (TR15) scrapers
      댓글 쓰기
    2. ProfiMixx 44 Disassembly, Removing the housing: 2 단계, 이미지 2개 중 1개 ProfiMixx 44 Disassembly, Removing the housing: 2 단계, 이미지 2개 중 2개
      • Removing the first part of the housing
      • Removing the rotary wheel, important pay attention to the black component so that the nose in does not break off (green mark).
      • Removing the second part of the housing
      댓글 쓰기
    3. ProfiMixx 44 Disassembly, Assembly of the housing I: 3 단계, 이미지 3개 중 1개 ProfiMixx 44 Disassembly, Assembly of the housing I: 3 단계, 이미지 3개 중 2개 ProfiMixx 44 Disassembly, Assembly of the housing I: 3 단계, 이미지 3개 중 3개
      • Make sure that the green marked elements are in the right place in both housings, the red element is only available once.
      • Make sure that the two strands run as marked in blue.
      • The white element must be in the rear position. (marked in orange)
      댓글 쓰기
    4. ProfiMixx 44 Disassembly, Assembly of the housing II: 4 단계, 이미지 3개 중 1개 ProfiMixx 44 Disassembly, Assembly of the housing II: 4 단계, 이미지 3개 중 2개 ProfiMixx 44 Disassembly, Assembly of the housing II: 4 단계, 이미지 3개 중 3개
      • Lift the motor-gearbox-unit a little bit upwards so that you can insert the black element with the nose into the hole of the white element. (marked in green)
      • Insert the nose of the black element into the hole of the rotary switch, making sure it is oriented as shown.
      • Gently move the rotary switch so that it fits into the slot in the housing. (marked in blue)
      • Then you can tighten the upper housing part with the five screws (TR15).
      댓글 쓰기
결승점
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
Justus Klingler
회원 가입일: 12/23/20
531 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 19
지난 30일: 54
전체 시간: 1,925
