주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
ProntoTec Axius Battery Replacement
필요한 것
  1. ProntoTec Axius Battery Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Make sure the device is completely turned off before you begging taking it apart to avoid electrocution risks.
    • Place the tablet face-up on a flat table
    댓글 쓰기
  2. ProntoTec Axius Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Starting near the headphone port, fit the flat end of the spudger in between the screen and back case.
    • Pry the back case from the screen around each point on the device to release the clips securing the case halves to each other.
    댓글 쓰기
  3. ProntoTec Axius Battery Replacement: 3 단계, 이미지 1개 중 1개
    • Gently remove the back case of the device and lay it in a flat surface as shown in the photo.
    • Make sure not to sever the wires (red and black) connected to the speaker that is located in the back case.
    댓글 쓰기
  4. ProntoTec Axius Battery Replacement: 4 단계, 이미지 1개 중 1개
    • Using a spudger remove all the tapes that touches the battery.
    • Be careful not to cute any wires that are under the tapes
    댓글 쓰기
  5. ProntoTec Axius Battery Replacement: 5 단계, 이미지 1개 중 1개
    • Using a soldering iron, heat up the contact point of the red wire from the battery and the motherboard.
    • When the solder begins to melt, use pliers to gently pull the wire from the motherboard
    • Don't leave the soldering iron too long on top of the wire so it doesn't melt any other component in the motherboard or surrounding the area.
    댓글 쓰기
  6. ProntoTec Axius Battery Replacement: 6 단계, 이미지 1개 중 1개
    • Repeat Step 5 on the black wire connecting the battery to the motherboard as shown in the photo.
    댓글 쓰기
  7. ProntoTec Axius Battery Replacement: 7 단계, 이미지 2개 중 1개 ProntoTec Axius Battery Replacement: 7 단계, 이미지 2개 중 2개
    • Using a spudger, gently pry the battery from the back of the screen to remove it from the device.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
Antonio Irons
회원 가입일: 10/20/16
441 평판
안내서 4개를 작성함
UMass Dartmouth, Team 5-3, Martin Fall 2016 UMass Dartmouth, Team 5-3, Martin Fall 2016 회원
UMASSD-MARTIN-F16S5G3
3 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 27
전체 시간: 587
