주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
ProntoTec Axius Camera Replacement
필요한 것
    1. ProntoTec Axius Camera Replacement, Camera: 1 단계, 이미지 1개 중 1개
      • Make sure the device is completely turned off before you begging taking it apart to avoid electrocution risks.
      • Place the tablet face-up on a flat table.
      댓글 쓰기
    2. ProntoTec Axius Camera Replacement: 2 단계, 이미지 1개 중 1개
      • Starting near the headphone port, fit the flat end of the spudger in between the screen and back case.
      • Pry the back case from the screen around each point on the device to release the clips securing the case halves to each other.
      댓글 쓰기
    3. ProntoTec Axius Camera Replacement: 3 단계, 이미지 1개 중 1개
      • Gently remove the back case of the device and lay it in a flat surface as shown in the photo.
      • Make sure not to sever the wires (red and black) connected to the speaker that is located in the back case.
      댓글 쓰기
    4. ProntoTec Axius Camera Replacement: 4 단계, 이미지 1개 중 1개
      • Remove only the yellow tape that touches the battery.
      • Be careful not to cut or damage the wires (red and black) that are under the yellow tape.'
      댓글 쓰기
    5. ProntoTec Axius Camera Replacement: 5 단계, 이미지 2개 중 1개 ProntoTec Axius Camera Replacement: 5 단계, 이미지 2개 중 2개
      • Use the flat end of the spudger to gently pry the top left corner battery from the back of the screen in order to access the camera.
      댓글 쓰기
    6. ProntoTec Axius Camera Replacement: 6 단계, 이미지 3개 중 1개 ProntoTec Axius Camera Replacement: 6 단계, 이미지 3개 중 2개 ProntoTec Axius Camera Replacement: 6 단계, 이미지 3개 중 3개
      • Use the spudger to lift the black clamp as shown in the photo to disconnect the camera from the motherboard.
      댓글 쓰기
    7. ProntoTec Axius Camera Replacement: 7 단계, 이미지 2개 중 1개 ProntoTec Axius Camera Replacement: 7 단계, 이미지 2개 중 2개
      • Disconet the camera from the motherboard.
      • Pull the camera from the back of the screen.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Antonio Irons
회원 가입일: 10/20/16
441 평판
안내서 4개를 작성함
UMass Dartmouth, Team 5-3, Martin Fall 2016 UMass Dartmouth, Team 5-3, Martin Fall 2016 회원
UMASSD-MARTIN-F16S5G3
3 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 12
지난 30일: 32
전체 시간: 460
