주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
ProntoTec Axius Screen Replacement
필요한 것
    1. ProntoTec Axius Screen Replacement, Screen: 1 단계, 이미지 1개 중 1개
      • Make sure the device is completely turned off before you begin taking it apart to avoid risk of electrocution.
      • Place the tablet face-up on a flat table
      댓글 쓰기
    2. ProntoTec Axius Screen Replacement: 2 단계, 이미지 1개 중 1개
      • Starting near the headphone port, fit the flat end of the spudger in between the screen and back case.
      • Pry the back case from the screen around each point on the device to release the clips securing the case halves to each other.
      댓글 쓰기
    3. ProntoTec Axius Screen Replacement: 3 단계, 이미지 1개 중 1개
      • Gently remove the back case of the device and lay it in a flat surface as shown in the photo.
      • Make sure not to sever the wires (red and black) connected to the speaker that is located in the back case.
      댓글 쓰기
    4. ProntoTec Axius Screen Replacement: 4 단계, 이미지 1개 중 1개
      • Remove all of the yellow tape that is on the device with the spudger.
      • Be careful not to cut any wires that are under the tapes.
      댓글 쓰기
    5. ProntoTec Axius Screen Replacement: 5 단계, 이미지 2개 중 1개 ProntoTec Axius Screen Replacement: 5 단계, 이미지 2개 중 2개
      • Use the flat end of the spudger to gently pry the battery from the back of the screen.
      댓글 쓰기
    6. ProntoTec Axius Screen Replacement: 6 단계, 이미지 2개 중 1개 ProntoTec Axius Screen Replacement: 6 단계, 이미지 2개 중 2개
      • Use a spudger to lift all the ribbon cable clamps
      • Detach all three ribbon cables from the clamps
      댓글 쓰기
    7. ProntoTec Axius Screen Replacement: 7 단계, 이미지 3개 중 1개 ProntoTec Axius Screen Replacement: 7 단계, 이미지 3개 중 2개 ProntoTec Axius Screen Replacement: 7 단계, 이미지 3개 중 3개
      • Using a Phillips screwdriver (PH00), unscrew the motherboard from the device
      댓글 쓰기
    8. ProntoTec Axius Screen Replacement: 8 단계, 이미지 3개 중 1개 ProntoTec Axius Screen Replacement: 8 단계, 이미지 3개 중 2개 ProntoTec Axius Screen Replacement: 8 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      Heavy-Duty Spudger
      • Use the flat end of the metal spudger to remove the battery from the back of the screen of the device.
      • Avoid using metal when prying off the battery. For serious prying power, try using the heavy-duty plastic spudger.
      댓글 쓰기
    9. ProntoTec Axius Screen Replacement: 9 단계, 이미지 1개 중 1개
      • Remove the orange tab from the back of the screen as shown in the picture
      댓글 쓰기
    10. ProntoTec Axius Screen Replacement: 10 단계, 이미지 2개 중 1개 ProntoTec Axius Screen Replacement: 10 단계, 이미지 2개 중 2개
      • Use the flat end of the metal spudger to unclip and remove the screen from the casing.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
5다른 기여자 명과 함께
Antonio Irons
회원 가입일: 10/20/16
441 평판
안내서 4개를 작성함
UMass Dartmouth, Team 5-3, Martin Fall 2016 UMass Dartmouth, Team 5-3, Martin Fall 2016 회원
UMASSD-MARTIN-F16S5G3
3 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 30
전체 시간: 611
