주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Proscan Tablet Touch Screen Replacement
필요한 것
  1. Proscan Tablet Touch Screen Replacement, Touch Screen: 1 단계, 이미지 1개 중 1개
    • Tools necessary for task.
    • Starting from the left to right
    • Metal Spudyer
    • Plastic opening tool
    • Precision tweezer
    • Point pen tool
    • Driver with bit size J0
    댓글 쓰기
  2. Proscan Tablet Touch Screen Replacement: 2 단계, 이미지 1개 중 1개
    • The backing of the tablet is fastened by simply snapping it in. Using the metal opening tool, pry between the plastic backing and the edge, but do not remove it yet. Work your way around until you have them separated.
    댓글 쓰기
  3. Proscan Tablet Touch Screen Replacement: 3 단계, 이미지 1개 중 1개
    • Once you have finished going around the edges of the tablet, look inside.
    댓글 쓰기
  4. Proscan Tablet Touch Screen Replacement: 4 단계, 이미지 1개 중 1개
    • You will notice two wires still connecting the backing to the computer. These are for the speakers.
    댓글 쓰기
  5. Proscan Tablet Touch Screen Replacement: 5 단계, 이미지 1개 중 1개
    • You can remove the speakers with your hands to free the backing completely.
    댓글 쓰기
  6. Proscan Tablet Touch Screen Replacement: 6 단계, 이미지 1개 중 1개
    • Next the following highlighted spots are screws. These screws must be loosened to separate the motherboard and digitizer from the outer glass components. Remember lefty loosely, righty tighty. All screws were placed on a magnet board to ensure they did not roll away
    댓글 쓰기
  7. Proscan Tablet Touch Screen Replacement: 7 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • There is some tape wire that links the screen to the grey digitizer. This can be gently pulled apart by the tweezers
    댓글 쓰기
  8. Proscan Tablet Touch Screen Replacement: 8 단계, 이미지 1개 중 1개
    • Next focus on the camera and volume components along the edges highlighted here. The screws have already been taken out, gently pull them off.
    댓글 쓰기
  9. Proscan Tablet Touch Screen Replacement: 9 단계, 이미지 1개 중 1개
    • Gently lift the green motherboard from the grey digitizer to ensure that all screws have been removed. The only connection remaining should be a tape wire to the battery.
    댓글 쓰기
  10. Proscan Tablet Touch Screen Replacement: 10 단계, 이미지 1개 중 1개
    • The last step is to remove the grey digitizer from the screen entirely. Note that the blue battery and green motherboard will still be attached, move them as one part
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Cameron Denny
회원 가입일: 10/23/15
321 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 32
전체 시간: 6,187
