주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Purse Strap Replacement
필요한 것
    1. Purse Strap Replacement, Strap: 1 단계, 이미지 1개 중 1개
      • Find a replacement strap or a long, thin piece of fabric you want to use for your purse strap.
      댓글 쓰기
    2. Purse Strap Replacement: 2 단계, 이미지 1개 중 1개
      • Make sure the strap is the correct length for your carrying preference. For example: crossbody, one-shoulder, crook of the elbow, etc.
      • Measurements will vary depending on preference.
      • For this project, we will be sewing a one-shoulder strap.
      댓글 쓰기
    3. Purse Strap Replacement: 3 단계, 이미지 1개 중 1개
      • Put the strap through the handle attachments.
      • Fold the end over.
      • There should be about 1/2 inch to 1 inch room for sewing.
      • Note: once the strap's end is folded over, make sure there is enough strap between each handle attachment for you to carry the bag.
      • Get your needle out and thread it with your preference of colored thread. We have used black.
      댓글 쓰기
    4. Purse Strap Replacement: 4 단계, 이미지 2개 중 1개 Purse Strap Replacement: 4 단계, 이미지 2개 중 2개
      • Fold the strap so there is a half-inch between the stitching line and the handle attachment.
      • Sewing
      • Start on one edge and push the needle through both piece of strap.
      • Once the bit of thread is pulled through, go through the strap again, this time a pinch to the side of where you came up.
      • Repeat this until you have sewed a stitch across the entire width of the strap.
      • After reaching the opposite end, pull the needle through, bringing up as much excess thread as it allows. Note: do not pull too hard or the thread will rip.
      • Tie a knot at the end, keeping the knot close to the base of the thread. Repeat until you believe the knot is strong enough to hold.
      댓글 쓰기
    5. Purse Strap Replacement: 5 단계, 이미지 1개 중 1개
      • After you reach the other side of the strap's width, sew backwards on top of the existing seams for a locking stitch.
      • Cut excess string.
      댓글 쓰기
    6. Purse Strap Replacement: 6 단계, 이미지 1개 중 1개
      • Repeat steps 3-5 on the opposite handle attachment.
      댓글 쓰기
    7. Purse Strap Replacement: 7 단계, 이미지 1개 중 1개
      • After repeating the steps, each side of your strap should be sewed onto the handle attachments.
      댓글 쓰기
결론
Make sure the stitches are secure by gently tugging on the strap. If it does not come un-stitched, then you are finished with your repair.
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Annie Chapman
회원 가입일: 10/20/17
112 평판
안내서 1개를 작성함
Missouri Western, Team S1-G6, Adkins Fall 2017 Missouri Western, Team S1-G6, Adkins Fall 2017 회원
MWSU-ADKINS-F17S1G6
3 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 14
지난 30일: 64
전체 시간: 2,637
